Here is out of the owners manual: = contact your smart center, thats alot of help.
Engine oils
Engine oils are specifically tested for their
suitability in our engines and durability for
our service intervals. Therefore, only use
engine oils and oil filters required for vehi
cles with Maintenance System. For a listing of
approved engine oils and oil filters contact an
authorized smart center.
! Using engine oils and oil filters of specifi
cation other than those expressly required
for the Maintenance System, or changing of oil
and oil filter at change intervals longer than
those called for by the Maintenance System
will result in engine or emission control
system damage not covered by the smart
Limited Warranty.
Please follow Maintenance System recommen
dations for scheduled oil changes. Failure to
do so will result in engine or emission control
Limited Warranty.
Engine oil additives
! Do not blend oil additives with engine oil.
They may damage the engine.
Damage or malfunctions resulting from
blending oil additives are not covered by the
smart Limited Warranty. Any authorized smart
center will provide you with additional infor
mation.
