My drivers side window is incredible hard to move. Window motor strains to move it.
I have disconnected the window from the window regulator and tested the motor. The motor and regulator runs freely and quickly. I moved the regulator all the way to the bottom and then attempted to move the window by hand.
The window does not slide smoothly in the tracks. I cleaned the tracks and lubed them with silicon spray, but the window still does not slide easily.
I loosened the bolts at the bottom of the regulator and try to adjust the angle of the regulator but have not had any results.
Any help would be greatly appreciated.
~Pard
~Pard
