Windshield Washer Tank Leaking - Smart Car of America Forums : Smart Car Forum
Old 06-18-2009, 06:14 AM   #1 (permalink)
My windshield washer tank is leaking a lot of washer fluid on the ground. Has any one had this problem and if so what did they find.
I will call the dealer and find out if the porblem is covered under the smart sponsered extended service contract.
Old 06-18-2009, 08:18 AM   #2 (permalink)
mark08859's Avatar
If you have a 2008, it should be covered under the basic warranty.
mark08859 is offline   Reply With Quote
Old 06-18-2009, 08:23 AM   #3 (permalink)
I have a 2008 with 35,000+ miles on it so the basic warranty is long gone.
Old 06-18-2009, 08:57 AM   #4 (permalink)
jefferios's Avatar
Did you look around, is it the connection to the hose from the tank? Is it the tank itself? The fluid isn't that dangerous to deal with...poke around. If you have the extended warranty it should cover it anyway.
But if you can find the leak source yourself you may be able to fix it yourself...it could even be a loose connection!
jefferios is online now   Reply With Quote
Old 06-18-2009, 09:45 AM   #5 (permalink)
yes I looked aroun but the tank id tucked into a tight space and hard to see anything.
Old 06-22-2009, 12:53 PM   #6 (permalink)
Yes I have seen one so far that came unconnected at the tank. To be honest I could not get my hand up in there is reach it from the top. I ended up putting the vehicle in the air and removing the lower splash guards to reconnect it.
Very tight fit.
smartSEATTLE is offline   Reply With Quote
Old 06-26-2009, 01:34 PM   #7 (permalink)
Took the smart to smart center Tulsa to have the windshield-washer leak checked out. The tank has a crack in it so it will have to be replaced "but" the tank is on backorder, the national parts warehouse for smart USA is in Tulsa, OK. The tank will not be in until August.
On a positive note the repair, minus the $100 decductable, will be paid by the smart extended warranty. I said smart extended warranty because that is how it is listed on the work ticket.
Old 06-26-2009, 03:22 PM   #8 (permalink)
Well at least at this time of year you can just keep filling it with water
Old 07-09-2009, 01:55 PM   #9 (permalink)
The new tank came in so I took it to the smart center in Tulsa. The total charges for the repair were:
Labor 3.5 hours $332.50
Washer Tank $ 40.01
Tax $ 3.41
My cost was $100.00 the rest was paid by the smart extended warranty.
The repair took about 3.5 hours, they had to remove the front fenders, front bumper, cowl, radiator core support, and wiper assembly to get to the tank.
I hope this is the only time I need to use the extended warranty but I am happ that I have it.
Old 07-11-2009, 09:58 AM   #10 (permalink)
May sound dumb, but is the leak in the front or back? I know jetfuel had a problem with the hose going to the back washer
Didn't read far enough to see the "crack" in the tank . My bad
What this car needs is.... (a windshield washer fluid indicator) jetfuel smart Modifications 45 02-18-2010 11:58 PM
Oil Drain Plug/Washer Old smart smart Operation and Maintenance 18 01-18-2010 12:47 PM
Problem with water leaking while washing Montana Smart 1 smart General Discussion 12 09-19-2009 06:52 PM
Roof Leaking Bill&Barb smart Operation and Maintenance 58 09-02-2009 11:32 AM
Windshield Washer SBibbo smart Operation and Maintenance 2 02-17-2008 02:04 PM
