Is your Air Conditioner freezing up / not cooling? - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 06-17-2008, 07:10 AM   #11 (permalink)
brian r's Avatar
I'd have the system pressure checked again. Last week when it was 95-98* here, I took a 4-hour round trip to Boston with the a/c on recirculating while set at the lowest temp setting. No problems.
Old 06-17-2008, 12:02 PM   #12 (permalink)
We are talking about a small compact system here folks. Run this thing on a low or medium fan in recirculate on the coldest setting in high humidity and your A/C will become an icemaker!!
High fan, coldest setting, fresh or recirc. is OK, if it starts to freeze up, and you'll know because the air flow from the vents decreases, bump up the temp setting to 70 deg to add some heat to the air box and force the ice of of it.
The first thing and airconditioning system does is wring the moisture out of the air, then it starts to cool the air. The A/C unit is the dehumidifier!! That's why it is activated in defrost. It is the action of the A/C that defogs (dehumidifies) your windows in winter.
Old 07-29-2010, 05:49 PM   #13 (permalink)
Where on a 2005 SMART can I find the place to add Freon?
LindasSmart is offline   Reply With Quote
Old 07-29-2010, 06:06 PM   #14 (permalink)
donnyonee's Avatar
its a evaporator freeze up , not condensor.
im not sure of the air flow ducts but maybe check the inside filter, blocked airflow will freeze the evap too.
donny
FCF V-2
Euro-Kool Rear Panel
PCV Accumulator
Style-Up wheel bolt covers
Old 07-29-2010, 07:47 PM   #15 (permalink)
SmartDigger's Avatar
Mine works great as long as I do not run it on coldest setting low air flow when real humid. Like Dunerunner said. great Ice maker. Nature of the beast. any system will freeze up under that condition.
Old 08-25-2010, 01:32 PM   #16 (permalink)
shack01's Avatar
Hmm, I have the same question. BTW, its not Freon anymore, but i think i know what you mean. Just finished changing the front brake pads so after this break i plan to go back out and find the service port. I'll be back in a few, hopefully.
tm
shack01 is offline   Reply With Quote
Old 08-25-2010, 01:51 PM   #17 (permalink)
tm
For all things smart: Evilution - Smart Car Encyclopaedia
Old 08-25-2010, 01:57 PM   #18 (permalink)
shack01's Avatar
No luck. Hoping it was under the bonnet but didn't see it there nor in the engine compartment. Perhaps someone has a mx manual by now and can let us know.
tm
Old 08-25-2010, 02:06 PM   #19 (permalink)
tm
shack................
"ours" IS under the bonnet................behind and below the passenger side headlight .................just look around, you'll see it
Old 08-28-2010, 09:49 PM   #20 (permalink)
My air/fan will not turn on when I start the car. On most days it will kick in after about 5 minutes of driving then works fine - until I stop then try to start the car again. I took it to the dealer and they said nothing is wrong.
korgiejackson is offline   Reply With Quote
Air Conditioner Performance MichaelJ smart General Discussion 50 05-31-2008 07:56 AM
Does 'defrost' setting, use air conditioner? mr_Cash smart Operation and Maintenance 15 03-06-2008 05:12 PM
freezing rain t-bone smart General Discussion 4 03-04-2008 03:58 PM
