LexLuthor,
I'm nowhere near California (Georgia) but if our paths were to cross I would certainly do some of it for you. Changing the TIK pipe, physical clutch lube and adjustment (i don't have the ability to program it), swapping out the air filter, adding a dump valve, replacing the intercooler hoses with Forge silicone and all of that would take me about a day. I go slow and document what was connected where and all of that. Especially when tinkering with someone else's car
Delipping the intake is an easy mod though. Find it here:
http://www.evilution.co.uk/index.php?id=229
Manual cluth adjust (helps with smoother shifting) is not too bad either as long as you can get under the car. Find instructions here:
http://www.evilution.co.uk/index.php?id=331
