450 Engine Mod - Page 3 - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Model Discussions > Original (450) smart fortwo
Old 10-07-2009, 06:56 AM   #21 (permalink)
Sorry to be a pain but how many quarts will I need?
cfreidma is offline   Reply With Quote
Old 10-07-2009, 06:59 AM   #22 (permalink)
2
For all things smart: Evilution - Smart Car Encyclopaedia
Old 10-09-2009, 06:48 AM   #23 (permalink)
thanks chiefmc.
I found the procedure for changing the tranny oil on evilution and printed it. As soon as the oil comes in, I'll give it a whirl.
I find the shifting beween 1st and 2nd a little sluggish (hesitant). In traffic any hesitation causes some people to start changing lanes as they must think they're going to get stuck behind a slug.
Old 01-26-2010, 01:14 PM   #24 (permalink)
briansmart's Avatar
Its about 1.5 quarts to fill the transmission. Do not overfill the transmission. I know some people say it doesn't matter but phyiscal space has limitations. We don't want to put any unnecessary and excessive stress on the filter, gasket, etc.
briansmart is offline   Reply With Quote
Old 01-26-2010, 05:56 PM   #25 (permalink)
lebikerboy's Avatar
The other thing to do is lube the clutch actuator, it makes a real difference in shifting smoothness...
Fixing a slow actuator
Old 02-05-2010, 11:17 AM   #26 (permalink)
briansmart's Avatar
Excellent reminder, lebirkerboy.
I have done that, however, I find it doesn't make much of a difference for me.
Old 02-05-2010, 03:55 PM   #27 (permalink)
24-42's Avatar
Originally Posted by Leroy View Post
On the 450 you use Dexron 3 only and the 451 you use 75-90W. When you change the oil on the 450 after lots of miles the red oil changes color to gray. The 75-90W should only be used in an emergency. Just like General Motors used Dexron 3 in the 80's in all the T-5 manual transmissions. It gives you better gas miliage. If you use gear lube your car will not shift very fast when it get cold outside. Because the 6 speed transmission was designed for the Dexron oil.
Leroy
Thanks again Leroy, Looking forward to meeting you at KC.
Donald LaFavor
Old 02-09-2010, 05:32 PM   #28 (permalink)
briansmart's Avatar
Just an update. I found out why my clutch does not shift smoothly even though I have lubed it and done the physical adjustment. The wrong type of transmission fluid is in my transmission. I have the fluid that is for the 451 and not the 450.
I believe an earlier post stated that the 450 uses the Dexron III fluid and that is correct. Mine has the 75W-90 stuff for the 451s
Looking for some Dexron III now so I can change the fluid this weekend.
Of course now the other thing is I need the transmission to be retaught (via MB Star) and any updates for the computer.
Really, really, really looking forward to the Nationals and seeing Leroy and/or Leonard (and their MB Star systems) there!!!
Old 02-09-2010, 07:05 PM   #29 (permalink)
Leroy's Avatar
I just hope I can be there but the Air Force reserves are making us have an inspection the weekend of the Nationals. What ever it takes I will try to be there to program all the cars that I can.
Leroy
Leroy is offline   Reply With Quote
Old 02-10-2010, 08:45 PM   #30 (permalink)
briansmart,
If I recall correctly you're in Denver - maybe wrong.
However, if that's the case and you ever get into a real jam, I have the Star System and have used it on my 2005 passion successfully to make my extra FOB, adjust the clutch, tranny and upgrade the software and run diags. I know - I'm so proud - had a little help from a friend. In any case, just thought you should know. And don't sweat the Dextron III. Checker auto parts has it.
Upgrading engine dgtracy New Members Area 36 Today 06:28 AM
Engine Types agent00mcfly Original (450) smart fortwo 6 01-27-2009 09:45 AM
Engine questtions... racer smart Operation and Maintenance 14 01-12-2009 08:53 PM
engine light john2036 smart General Discussion 4 06-18-2008 01:12 PM
Hot engine stilamama smart Operation and Maintenance 7 05-03-2008 07:09 PM
