Go Back   Smart Car of America Forums > Smart Car Model Discussions > Original smart fortwo (450)
Old 09-19-2009, 04:35 PM   #11 (permalink)
smarts@AF Museum!
Originally Posted by rayman1946 View Post
OK, I hot wired the compressor, and the clutch kicks in. There is some kind of switch/ resistor/ sensor/ or something that the wires go in and out of right before the compressor clutch. It is bolted into the compressor housing with a little bracket and a philips screw. What is this thing ?????? I can't get power to go through it. I'm still baffeled with this AC..... Where is the dryer located???
If it's like the 451 all the A/C stuff (minus compressor) is up front - dryer is in there somewhere. As for that switch/relay (?) can you see a part number? Might be worth at least pricing one through a Canadian dealer or one of our supporting vendors with EU sources.
Old 09-19-2009, 08:20 PM   #12 (permalink)
The AC in my (new) 2005 doesn't work either.
I think I'll wait till next summer to worry about it.
Sounds like an adventure to get this working.
cfreidma is offline   Reply With Quote
Old 09-20-2009, 07:02 PM   #13 (permalink)
Leroy's Avatar
Drive: 02 and 08 smart, Ferrari
The AC on these cars are just as easy to work on as any other car. Check your pressure on the LOW side and tell me what it is. It is behind the right fog (turn signal G&K cars) light. There are two wires that can come off of the low pressure sensor on the AC compressure. If one of them comes off the AC compressure will not come on. Now of course there is a posabliity that the SAM unit needs to be told again the the car is equiped with AC.
Leroy
Leroy is offline   Reply With Quote
Old 09-20-2009, 07:09 PM   #14 (permalink)
Leroy's Avatar
I forgot, if you have a Mercedes DAS go to the Main Menu then to Systems then to N3/10 Meg Motor then to Control Unit Adaptation then to Air Conditioning Activation then to F3 Start and put in the TAN code. This is only done if the car has lost the AC programing or it has never had AC to begin with.
Leroy
Old 09-22-2009, 10:19 AM   #15 (permalink)
briansmart's Avatar
Drive: 2005 450 Passion, 2006 HHR
I have to get my hands on one of these Mercedes DAS systems
briansmart is offline   Reply With Quote
New Work Wheels!!! smartracing Smart Car Wheels & Tires 9 12-01-2008 09:55 AM
Three smarts at work nscaler Smart Car General Discussion 7 09-24-2008 02:59 PM
Would this work for a under the seat sub? abseventeen Audio & Video 22 07-09-2008 04:06 AM
Stranded at work Karl Roth Smart Car Operation and Maintenance 19 06-07-2008 03:39 AM
would these work without adapters? SmartPassion Smart Car Wheels & Tires 3 04-07-2008 05:21 AM
