Door Handle Removal??? - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Model Discussions > Original (450) smart fortwo
Old 07-01-2009, 10:39 AM   #1 (permalink)
rayman1946's Avatar
Ok, I'm a 450 newbe, but I'm trying to remove my outside door handle assembly to lube the cable,( it sticks and seems tight) I did like instructions said to remove screw and slide assembly back, but it just won't come off Ok, whats the trick? Do you have to pry it off? I tried both sides...many times. .I don't want to break anything, but I can't figure it out. Help....
rayman1946 is offline   Reply With Quote
Old 07-01-2009, 11:23 AM   #2 (permalink)
Always good to check evilution.co.uk.com first; this may be what you're looking for: Evilution - Smart Car Encyclopaedia
Old 07-02-2009, 08:20 AM   #3 (permalink)
rayman1946's Avatar
Thats where I got the info on how to remove it. But they don't seem to come off....
Old 07-04-2009, 03:33 AM   #4 (permalink)
smart142's Avatar
Keep trying! Those are the right instructions and they will come off.
Just did 2 on my 450.
Use an oil film spray for the internal mechanism of the lock assemby, and white lithium grease for the external latch.
Good luck!
smart142 is offline   Reply With Quote
Old 07-05-2009, 05:02 PM   #5 (permalink)
rayman1946's Avatar
Ok... I finally got it off, after a lot of wiggling and jiggling, and prying. Tryed lubing cable and put it back together, but still door handle pulls stiff and jerky. Must be the plastic covered cable sliding inside the plastic cable housing, plus the way it is all twisted around when it is put on. Maybe cable should not be lubed. Maybe it should be dry? Just not a good feel to have door handle tight and sticky like that.
ForFour - year '04 Exterior Door Handle Removal elke martin smart Forfour 2 03-31-2009 05:48 PM
ForFour - year '04 Exterior Door Handle Removal elke martin New Members Area 0 03-31-2009 01:40 PM
Door panel removal Westfield 11 smart General Discussion 5 02-20-2009 11:11 PM
Door handle buzz SmartAzz smart General Discussion 9 02-18-2009 08:14 PM
Door handle/door pull mods smartdot smart Modifications 4 12-09-2008 04:59 PM
