Hi I'm Hank (Q: 450 leaking oil?) - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Model Discussions > Original (450) smart fortwo
Old 09-18-2009, 12:35 PM   #1 (permalink)
Drive: Forfour
I was just thinking of buying 2005 fortwo with 15600kms and it seems to be leaking oil on the turbo?? what do you think?? thx hgb
beaudoin is offline   Reply With Quote
Old 09-18-2009, 02:31 PM   #2 (permalink)
lebikerboy's Avatar
Get it checked out by a Canadian smart dealer as it could be lots of $$$ to repair...
Old 09-20-2009, 08:15 PM   #3 (permalink)
Leroy's Avatar
How bad is it leaking? Most smart cars will have some oil around the turbo after a lot of miles. Wash it off a take a drive to see how much it is leaking. You will always see some oil around the TIK pipes with age. If the oil is dripping all the time you have a problem. If the oil is dripping from the intercooler you could have a broken intercooler. This happens on the CDIs a lot.
Leroy
Leroy is offline   Reply With Quote
Old 09-22-2009, 11:16 AM   #4 (permalink)
briansmart's Avatar
I had the same issue with oil at the low end of the TIK pipe (where it connects to the turbo). I have yet to see any there after replacing my TIK pipe.
However, after fitting the Forge dump valve and intercooler hoses, I have noticed a bit of an oil leak coming from where the dump valve attaches to the intercooler. I've reseated and re-tightened everything, however there are still a few drips. I'm chalking it up to some residual/leftover oil in the system from before the change. I've checked my oil level many times and its still the same (3/4 of the way to the full line on the dip stick).
Anyone have any thoughts?
briansmart is offline   Reply With Quote
Windshield Washer Tank Leaking Okie Boy smart Operation and Maintenance 15 09-17-2011 06:12 PM
Problem with water leaking while washing Montana Smart 1 smart General Discussion 12 09-19-2009 06:52 PM
Roof Leaking Bill&Barb smart Operation and Maintenance 58 09-02-2009 11:32 AM
