MPH, manual shifting, non E10 gas - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Model Discussions > Original (450) smart fortwo
Old 02-25-2008, 07:37 AM   #1 (permalink)
ASmartMan's Avatar
Hey All
Some 450 owners have stated they get 50 MPG+ in their Smarts, as can be seen here I hit 48 MPG just once and get mid 40s the rest of the time http://www.spritmonitor.de/en/detail/194504.html
So yesterday, when fueling up in the mountains, I filled up with Shell V power 93 octaine and decided to drive in 100 % manual.
A Disclaimer needs to be made here: 1, first time I've used a non E10 gas, 2: first time I shifted exclusivly in manual 3: used back roads (rt 28 with a speed limit of 55 mph).
Now having said that, my first blob usually goes out @ 106 to 116 miles mark, this time my first blob didn't go out until the 132 mile mark (almost a 20% increase).
Of course only time will tell if these advantage hold true for the rest of the tank, but I have high hopes.
The only thing I will not know in the end (if the mileage stays high is), was it the non E 10 gas, manual shifting, or the 55 MPH speed limit, or a combo of all 3.
My tire pressure is 32 PSI (all the time) I did the DE-Lip and the K&N filter 3 tanks ago with no noticable difference so if my mileage does increase then these factors can be ruled out.
It will be at least a week before we know the final results (40 mile per day commute), but I will update with the final results.
ASM
EDIT: Update, 2nd blip just went out @ 201 miles still looking good
EDIT: 3rd blip went out @ 263 miles
Edit: 4th blib went out @ 323 miles
Refiled with V93 octane Shell (this one has E10 added) I had 366 (and still 1 blip left) miles on the trip and it took 7.78 gallons for a total of 47 MPG .
Will repeat using exact conditions as with last tank, this will tell us if the E10 plays much of a roll.
Will update as gas gets used
ASM
Last edited by ASmartMan; 03-01-2008 at 03:13 PM. Reason: to update 4th blip and fueling
Old 02-25-2008, 07:49 AM   #2 (permalink)
Hi ASM where did you find non ethonol fuel around here. That alone will get you more power and milage.
Karl
Old 02-25-2008, 07:55 AM   #3 (permalink)
Lgaruti's Avatar
ASM, Pardon my ignorance but what is the "DE-Lip" think?
Thanks
Lgaruti is offline   Reply With Quote
Old 02-25-2008, 07:55 AM   #4 (permalink)
dcrooks's Avatar
Originally Posted by ASmartMan View Post
Hey All
ASM
Can you explain "DE-Lip and the K&N filter"? Thanks!
David
dcrooks is offline   Reply With Quote
Old 02-25-2008, 09:25 AM   #5 (permalink)
tbranca's Avatar
same here ? whats he talking about. I feel like suck a dumb AZZ
tbranca is offline   Reply With Quote
Old 02-25-2008, 09:31 AM   #6 (permalink)
Here's a link to the air intake de-lip mod:
http://www.evilution.co.uk/index.php...=95&men=engine
K&N is a low restriction air filter: www.knfilters.com/
Keep in mind this all applies to the 450 version.
Old 02-25-2008, 09:32 AM   #7 (permalink)
He drives a 450 you both drive 451's he is talking about a modification to the airbox.
Old 02-25-2008, 10:21 AM   #8 (permalink)
24-42's Avatar
Delipping is not a mod to the airbox, it is a mod to the inlet pipe. The K&N is just a much better air filter.
The above is true but, has anybody investigated the availability of a K&N for the 451 ?
Has anyone pulled the air intake grill to see if that stupid lip is on the 451 ?
Both of these mods with an S-Mann scoop (450) have really helped my car.
I've done several other things, I don't talk about because all it would do is start a controversy. I have enough trouble already with people on this board that want to argue with me after I have, 'Been there & Done that'
Ignorance is bliss.......... And bliss is expensive !
If I drive 'Light-footed' (I usually don't) I get between 55-60mpg.
Driving with 'Verve', I average 48-52mpg (City & Hwy)
Before anybody asks; I HAVE MODEL 450 !
Donald LaFavor
Old 02-25-2008, 10:42 AM   #9 (permalink)
Senior Smartie
jonnysan's Avatar
Do you know what the purpose of that lip was?
Donald LaFavor
I certainly seems to be a deterent to good flow which is what you would want there....having the lip on there, that is. Removing it seems a good thing.
Old 02-25-2008, 11:03 AM   #10 (permalink)
ASmartMan's Avatar
Blocks water
jonnysan
People say it it to stop water from getting into the air box, BUT the air box has a drain hole in it, so even if water does get in it has a place to drain out.
The exact K&N filter http://www.knfilters.com/search/prod...px?Prod=E-9257
Also, the things I post here in the 450 thread are spific to the 450, if I find things that are for both I'll post in the general section ie. My Smart and the snow
ASM
Service Manual? MSOEMiller smart General Discussion 22 04-04-2011 05:28 PM
451 Full Manual & Quick Manual (US Version) rrrucke smart Operation and Maintenance 28 02-26-2009 03:08 PM
electric-auto manual or manual with clutch pedal, your favorite? mr_Cash smart General Discussion 47 02-19-2008 10:05 AM
451 Service Manual Available? oldbike smart Operation and Maintenance 1 01-30-2008 10:28 AM
451 Owner's Manual spdickey smart Operation and Maintenance 4 01-04-2008 06:31 PM
