Muffler Pipe Cracked - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Model Discussions > Original (450) smart fortwo
Old 10-28-2009, 03:37 PM   #1 (permalink)
rayman1946's Avatar
Why is my muffler pipe cracking around where it bolts up near to flange at turbo? It was cracked with only 1000 miles on it. I removed muffler and Tig welded cracks, now it is cracked again right next to where I welded it. Is there some reason for this, or a known fix? (Its on a 2005 smart 450)
rayman1946 is offline   Reply With Quote
Old 10-28-2009, 03:54 PM   #2 (permalink)
For sale pm for details
Turbo42's Avatar
turbos are known to crack manifolds
Old 10-28-2009, 09:24 PM   #3 (permalink)
Leroy's Avatar
It is a problem with some G&K cars. There is a small cat that was added to the muffler which weakens it. Replace the muffler with an aftermarket muffler and you will not have any problems.
Leroy
Leroy is offline   Reply With Quote
Old 10-29-2009, 12:57 AM   #4 (permalink)
Drive: Pulse
This works!
The weight of the 450's muffler with built-in catalytic converter makes the rigid downpipe susceptible to breakage due to the fact that the engine, which vibrates, is connected to the muffler, which is rigidly mounted to the transmission case, which doesn't.
Here's one simple mitigation... use spring-loaded manifold bolts and file a radius shoulder on the inside of the mounting flange where it presses against the down-pipe trumpet.
Old 10-29-2009, 05:48 AM   #5 (permalink)
rayman1946's Avatar
I think that might be the solution. Great Idea. I will do that when I take muffler off to weld it again. Thankyou very much. I'll let you know how it works in time.
Old 10-29-2009, 06:55 AM   #6 (permalink)
ASmartMan's Avatar
rayman1946
You may also want to contact G&K, they may be able to help as well.
Just a thought
ASM
Old 10-30-2009, 03:00 PM   #7 (permalink)
idahosmart's Avatar
Some of the G&K conversions have had this crack. Mine so far has not cracked, but I did get a letter from them over a year ago stating that they would pay for the repair if needed.
Tom
idahosmart is offline   Reply With Quote
Old 11-02-2009, 11:27 AM   #8 (permalink)
briansmart's Avatar
Brilliant fix!! I will do this once I replace the spark plugs in my car.
briansmart is offline   Reply With Quote
Old 11-11-2009, 09:57 AM   #9 (permalink)
hoov23's Avatar
Contact G&K, they were sending out new mufflers to people whose mufflers cracked because of the old cat. I don't know for sure if it's still covered, though, but it used to be.
hoov23 is offline   Reply With Quote
Old 12-24-2009, 07:20 AM   #10 (permalink)
all catalitics are covered by epa laws for 8 years 80,000 miles they must replace with new not repaired or a take off also by law. mine cracked and they tried to replace with a take off i filed a epa complaint and epa set them on the right path.
technician is offline   Reply With Quote
Brabus muffler vs Smart muffler magilly00 smart General Discussion 2 10-07-2009 07:18 PM
cracked panel--any glue or epoxy work to fix? the_dude smart General Discussion 7 07-20-2009 04:35 PM
Muffler for the diesel Brewster smart Operation and Maintenance 0 02-27-2009 02:55 PM
WTS - OEM Muffler?? graphix1998 Archive/obsolete (?) threads 0 09-11-2008 12:57 AM
Date Code Cracked on Reservation Number lhoboy smart News & Rumors 43 12-27-2007 07:36 PM
