Problem - Position lights not working / speedo illumination fails (first click of stalk) All other lights / indicators work fine
Car - Smart 4/2 2002 Pulse
Tried so far...
Fuse's 1 and 2 (7.5amp) Checked and removed. 12volts put to each fuse, speedo lights come on and position lights come on. Fault must be before the fuse box. As its not getting any power.
Light stalk stripped and cleaned. Checked for problems. Also supplied 12v direct to the stalk connector and still nothing.
It seems the fault is in between the stalk and the fuse box. Is this a direct wire of does it go through a seperate relay for the position lights ?
any help appriciated.
thanks
Steve
