Radio Does Not Work - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Model Discussions > Original (450) smart fortwo
Old 02-21-2008, 08:13 PM   #1 (permalink)
Radio Does Not Work
I Had To Get A New Battery When My Car Was 14 Months Old. No Warranty, Bought From Ford Dealership. New Battery $140 And My Radio Does Not Work. I Can't See Anything On The Cd That Will Help Me. Any Ideas???
okclarkkent is offline   Reply With Quote
Old 02-21-2008, 08:15 PM   #2 (permalink)
Carnut's Avatar
How about giving us a clue Clark that you probably own a 450 US conversion. They came with Sony Radios so that would be the first place to look - a Sony radio service center.
Old 03-03-2008, 07:11 PM   #3 (permalink)
Grundig or Sony?
Just in case its a Grundig, there is another potential problem. This assumes its a 450 model. When the battery is disconnected, it puts the radio into the SAFE mode. You cannot get it back on without the 4 digit reset code. Most often, the four digit code was on a card in the pullout tray just below the radio. Look carefully for it. If not there, go through your documentation, if any, that came with the car. See if there is a code somewhere in there. If there is no code and no card, you may end up having to get a Sony after all. The Grundig won't do you any good without the code and it may take a call to Germany to get the answer of the correct code. If you do find the code, use this process to reset the radio: Press the CD button, then use the four buttons below the radio, pressing the one on the far left first until the number on the readout area is the same as your first code number. Use same procedure for each of the next three numbers, then press the CD button again when you have the correct code showing. Your radio should immediately start to play. If you don't have a Grundig, you've wasted a lot of time reading this. Sorry.
Ron Gaus, asmartcar.com
rgaus is offline   Reply With Quote
Old 05-20-2008, 01:08 PM   #4 (permalink)
thinksmart's Avatar
thank you rgaus, was having this problem and had no idea how to fix it. Great explanation, luckily I still had the card in the tray and it worked perfectly. Couldn't have lived without music.
thinksmart is offline   Reply With Quote
Old 07-20-2008, 07:37 AM   #5 (permalink)
try evilution .co uk they will give you the code for $30.00
calentura is offline   Reply With Quote
How Does Warranty Work for Distant Owners? rgaus smart Delivery 25 07-03-2008 10:46 AM
Radio 10 mtnbyked smart fortwo (451 - US vehicle) 30 06-13-2008 11:24 AM
dealer fees- this might work? Lewis smart General Discussion 1 01-20-2008 02:39 PM
Don't you guys work SMART Off-Topic Cafe 9 11-14-2007 04:37 PM
smart work at MB dealers propes smart Operation and Maintenance 4 10-09-2007 04:23 PM
