What type of transmission oil does an 04 For Two Passion take. I have one that even after the selector is moved to neutral, it remains in Reverse and can not be started untill the car is rocked back and forth. I believe another shop may have put the wrong oil in the transmission.
Thanks
Bob T
Thanks
Bob T
Sounds like it is probably not a oil issue, but a clutch disc release problem.
you also need to check your brake lights are working cause engaging gears sometimes dont work without the brake pedal being used and the brake light switches are known to go defunkt !
And to add to that, the brake switch is a 2 part switch, 1 side does the lights, the other side does the electronics. Usually if it breaks, both sides go but it is possible for the electronic side to fail but the lighting side to still work.
__________________ www.evilution.co.uk - The home of 451 mods, fixes, ideas and information.
