Winter MPG - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Model Discussions > Original (450) smart fortwo
Old 02-10-2008, 03:15 PM   #1 (permalink)
ASmartMan's Avatar
Winter MPG
Hey All
Even though the colder air of winter does make the motor perform better, most complain about lower MPG during the winter.
As I thought about it (I too am getting lower MPG) I was wondering if my snow tires were the cause, I know that actually driving in the snow will affect my MPG (drag/resistance), yet I was wondering why my MPG has been down a little (figuring snow tires on dry pavement wasn't the cause).
Then I had a small DUH moment, because I drive to work before the sun comes up and come home after dusk (mid Oct to mid Mar) my lights are on for all of my commute as is my heater, so I did some quick calculations and SOME guessing.
Head lights draw 55 watts each (low beams) and assuming same 55 watts for high beams, running lights draw 12 watts each (X 4) and the heater (guessing, 2nd speed @ about 25 watts) indicators/LEDs guessing @ 10 watts.
For reference, 746 watts = 1 HP and we know the alternator output can exceeds the wattage demand of the car under normal use. Having said that and not knowing the efficiency of the alternator (lose to belt, fan, heat, converting AC to regulated DC, etc), I'll guess we'll be lucky if it is 40% efficient.
So what I am assuming (and it's a good assumption too) we get 298 watts per true motor HP. With a load of 193 watts (2 low beam bulbs,4 running lights, heater, and indicator/LED lamps) we consume .67 HP regardless if we are going 1 MPH or 100 MPH.
Our G&K Smarts produce 62 HP, but were not demanding that most of the time while driving around, most of the time (cursing) I would be surprised if we draw 20-25% of that potential (12 to 15 HP).
So in conclusion, there is a lot of guessing here but I wasn't looking to produce absolute numbers, just a model that could explain a reduced MPG during winter (other than driving in snow), SSOO a 5% loss in MPG could be attributed to lights and heater usage.
Just thinking out loud
ASM
Old 02-10-2008, 03:36 PM   #2 (permalink)
It may be simpler than that. Cold engine, longer warm up time, more drag on various engine and trans parts while waiting for warm up.
Old 02-10-2008, 03:39 PM   #3 (permalink)
rirover's Avatar
I always get about 5 mpg less in the winter with my diesel...I always thought it was the cold..and maybe the adatives in the fuel for the winter...but always get better mileage in the summer
rirover is offline   Reply With Quote
Old 02-10-2008, 03:55 PM   #4 (permalink)
GHammerly's Avatar
jwight is right, most of it will be from cold engine and fluids, a cold engine runs ritch until it warms up and cold oils generate mechanical resistance compared to a warmed up car.
And yes, snow tires have higher rolling resistance and electrical draw takes some of the efficiency away.
Also to a even lesser degree the colder denser air generates higher aerodynamic drag.
Sharing what I learned about winter tires. Harleyduo smart Wheels & Tires 6 12-30-2007 09:26 AM
Smart In Winter Tunefreak smart General Discussion 7 09-02-2007 10:10 AM
driving in winter conditions? terry New Members Area 2 08-20-2007 12:04 PM
