Am I the only one with a dead battery? - Page 2 - Smart Car of America Forums : Smart Car Forum
LinkBack (4) Thread Tools Display Modes
Old 09-18-2008, 09:45 AM   #11 (permalink)
As part of my personal PDI (POST Delivery Inspection) I load tested my battery. It was OK (though the ground strap wasn't particularly tight). June '08 build.
Old 09-18-2008, 09:53 AM   #12 (permalink)
Originally Posted by Dave777 View Post
This strikes me as evidence, combined with some of the other reports above, that the dealers know there is a problem with the original batteries, or at least some of them.
Yes there is and the original is not available in the US. The warranty is short enough, let them fix it now.
Old 09-18-2008, 10:46 AM   #13 (permalink)
IF the OEM battery is 8-3/16”L x 6-13/16”W x 7-3/4”H (overall measurements), Googling "Group 26R battery" will produce U.S. sources. Note, it is 26R not 26 (when you look at the long dimension with the posts closest to you, the positive post will be on the right end - the 26 is opposite).
Old 09-18-2008, 04:02 PM   #14 (permalink)
WilyB's Avatar
Thank you. The smart is still at the shop where they reported that everything (battery, alternator, current draw from the smart) is within specification, and that they have another smart in the shop for the same problem: battery will not last two weeks w/o being plugged into a trickle charger...
I guess, shall they return the smart "as is" to me, I shall invite the smart community to protest loudly and start looking for a better battery.
Old 09-19-2008, 09:14 AM   #15 (permalink)
fmaxwell's Avatar
Don't be too quick to blame the battery. Did the shop measure current with the car off, key out, doors closed -- like it would be when parked overnight? If not, you might want to give that a try.
What about hooking a portable scope to the battery and seeing if you get voltage dropouts when driving over road irregularities? If there's a loose connection, they might get a fine reading with the car sitting still whereas an in-use measurement might tell you a lot more -- like the alternator and/or voltage regulator glitching out.
Old 09-20-2008, 10:44 AM   #16 (permalink)
WilyB's Avatar
Update: No abnormal draw from the car, good alternator, good battery. SA is still attempting to get Penske HQs to confirm if it shall be considered normal for a smart's battery to die after a week or two...
SA's advice so far:
1) Drive more often,
2) Buy a battery tender (or in my case, remember to hook it up).
I am just curioous: is there a way to push start a smart?
Old 11-16-2008, 09:55 PM   #17 (permalink)
This isn't the first problem that I've had a dealer acknowledge that didn't result in a recall. When I had to have my car towed in to the dealer for lubrication of the shift lever they said "yeah we've had a lot of them with this problem."
Other common problems:
* The back glass latch tends to break.
* The front glass gets chipped and/or cracked by rocks astoundingly often to the point that many people don't bother fixing it.
* The gear shift levers were not lubricated in a large batch of cars (mine included) so the gear shift lever in those cars will eventually fail and stick in place.
* There were many cars (mine included) that had defective batteries that won't hold a charge over a few days so the car has to be jump started.
foxmajik is offline   Reply With Quote
Old 11-16-2008, 10:02 PM   #18 (permalink)
SA's advice so far:
Technically, yes, but it's a very bad idea. It could damage or destroy your gearbox or drivetrain linkage.
You're better off carrying one of those portable battery juicers or just calling roadside assistance.
If you didn't elect the Smart One Roadside Assistance (which I hope you did, it's saved my butt at least five times) you can get roadside assistance through Costco membership and most insurance companies at a small and extremely worthy extra charge.
However even if you do get Smart One Roadside Assistance don't count on them knowing anything about your car. Every time I have someone out to jump the car I have to show them how to remove the carpet and the passenger foot well filler module so they can get to the battery.
On the positive side, if there's anything wrong with your car other than needing a jump start and you have Smart One they'll load it up on the truck, take it to the dealership, fix it and then haul it back to you for free as long as the car's under warranty.
Old 11-16-2008, 10:29 PM   #19 (permalink)
mendo's Avatar
I would load test the battery and see if it has a weak cell.
that could draw it down.
if so, then replace and then use it often enough to keep it charged or augment with auxiliary charging.
I have had great result with a small solar charger when I leave it outside.
it keeps it fully charged.
if I am leaving it inside I use an automatic battery tender to keep it topped off.
Batteries like to stay at the state that they are in, if you leave them dead they will work their way dead pretty quick. If you leave them charged they like to stay charged.
I keep a few boat batteries fully topped off with an automatic tender and in the spring they fire right off.
Old 11-16-2008, 10:43 PM   #20 (permalink)
a battery tender works great for things that spend a lot of time in the garage.
The replacement Battery that smart gave me for my car was slightly larger than what was in the car originally. It required a new hold down bracket that they installed with the replacement.
This is what it looks like
The upside was the "factory" fix was free
The downside the car shifted like crap again for a while
HiHo
BTW a failed load test is what prompted replacement
dead battery
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f27/am-i-only-one-dead-battery-13998/
tjwarren's smart Bookmarks on Delicious This thread Refback 11-17-2008 11:18 AM
smart 451: Blogs, Photos, Videos and more on Technorati This thread Refback 10-15-2008 08:17 PM
smart 451: Blogs, Photos, Videos and more on Technorati This thread Refback 09-30-2008 06:25 AM
Smart Car Blog: smart center Chandler Arizona This thread Refback 09-17-2008 12:17 PM
Why is it so DEAD in the Ga chapter? 2micro4u South Atlantic Chapter 36 11-17-2009 12:57 PM
Why is my battery dead - I wish smart roadside was more helpful! SMART smart Operation and Maintenance 21 11-16-2008 10:08 PM
Advice on dead battery lakelouie smart Operation and Maintenance 24 04-24-2008 06:07 PM
