Am I the only one with a dead battery? - Page 3 - Smart Car of America Forums : Smart Car Forum
LinkBack (4) Thread Tools Display Modes
Old 11-17-2008, 08:11 PM   #21 (permalink)
If after a weekend my ScanGauge shows 11 volts when I switch key to position 1, is that reason enough to perform a load test? I don't have equipment for that myself; I could take it to Autozone and freak out the goobers there, I suppose.
Old 11-17-2008, 08:23 PM   #22 (permalink)
SunDiego's Avatar
My smart has been in the garage for a couple weeks now and the battery is dead... Nothing was running in the car.
Old 11-17-2008, 10:12 PM   #23 (permalink)
Yes
Old 11-18-2008, 12:32 AM   #24 (permalink)
Drive: Pulse
Check the electrolyte level in your battery - you may be running on fewer than 6 cells. Several Canadian smarties found their electrolyte was low, even right after PDI!
Mine was quite low when I checked it this summer, after 3 years on the road. Not desperately low, and there was no charge problems. Just checked it as part of routine annual maintenance.
Old 11-18-2008, 07:31 AM   #25 (permalink)
Help the ignorant, please
Originally Posted by Karl Roth View Post
Yes
Please help out this non-motorhead. What is a load test, how is it done and what do you learn from the results?
Thanks,
Michael
Old 11-18-2008, 08:01 AM   #26 (permalink)
Load test is putting a resistance load (large heating element)on the battery for a short time. By doing this it is possible to get the state of the batteries ability to properly function and recover from the high load. It will tell if there are internal problems with the battery.
Old 11-18-2008, 04:58 PM   #27 (permalink)
Thank you
Thank you very much for such a clear and succinct explanation!
Old 11-19-2008, 05:29 PM   #28 (permalink)
lebikerboy's Avatar
I got tired of checking the electrolyte so I bought an Optima redtop. Was also able to toss the silly little breather hose.
Old 11-24-2008, 11:39 AM   #29 (permalink)
Same here- ended up putting in an optima yellow top, since I leave the GPS/Weather on all the time. The replacement was a cinch, although I did need to put in a longer battery negative to ground cable. It's a good idea anyway, since the tin ground that comes standard is probably not sufficient to prevent some voltage loss at high current draw.
nsaamiller is offline   Reply With Quote
Old 11-24-2008, 02:18 PM   #30 (permalink)
http://www.optimabatteries.com/_medi...yDataSheet.pdf
These are great but they still produce hydrogen when you charge them (that silly vent tube) and they live in the passenger area of our car. Just wondering, run a spill proof in an other car and it is vented to the exterior
dead battery
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f27/am-i-only-one-dead-battery-13998/
tjwarren's smart Bookmarks on Delicious This thread Refback 11-17-2008 11:18 AM
smart 451: Blogs, Photos, Videos and more on Technorati This thread Refback 10-15-2008 08:17 PM
smart 451: Blogs, Photos, Videos and more on Technorati This thread Refback 09-30-2008 06:25 AM
Smart Car Blog: smart center Chandler Arizona This thread Refback 09-17-2008 12:17 PM
Why is it so DEAD in the Ga chapter? 2micro4u South Atlantic Chapter 36 11-17-2009 12:57 PM
Why is my battery dead - I wish smart roadside was more helpful! SMART smart Operation and Maintenance 21 11-16-2008 10:08 PM
Advice on dead battery lakelouie smart Operation and Maintenance 24 04-24-2008 06:07 PM
