dealer installed the license plate crooked - Smart Car Forums
 7Likes
post #1 of 33 (permalink) Old 07-28-2016, 11:37 AM Thread Starter
Quoted: 17 Post(s)
Hello,
I need some help please! I bought a 2015 Smart Car Brabus edition and the license plate was installed crooked on the rear panel. The dealer is to far away to return the vehicle to correct the problem so I need some advise and help from all of you.
Can I just raise the location up and re-attach? I see the two small horizontal marks on the rear panel that they put the screws through but it sits to low and it is also crooked! Is that a location that I can use to re-attach the license plate? Put new holes level between those marks? It needs to be raised up higher and re-attached so it is level. The screws are also only a half an inch long and won't affix the licesnse plate and frame to the vehicle. What length screw should I use?
Thank you for any and all help!!
Hartmn1 is offline
post #2 of 33 (permalink) Old 07-28-2016, 12:00 PM
stevenvillatoro's Avatar
Quoted: 1070 Post(s)
Was the car new or previously-loved when you bought it?
Did you see the issue before taking delivery, or after?
How crooked is the plate? Put a level across the edge of the license plate to measure.
stevenvillatoro is offline
post #3 of 33 (permalink) Old 07-28-2016, 12:07 PM Thread Starter
Quoted: 17 Post(s)
The car was new and I didn't see it until after delivery. It's just slightly crooked. And the screws are only 1/2 inch long which is to short to attach a factory smart license plate frame.
Hartmn1 is offline
post #4 of 33 (permalink) Old 07-28-2016, 12:24 PM
If your panels are nonmetallic, then you could ask the dealer to send you a replacement hatch panel which would come with a molded-in color that would be a perfect match.
Otherwise, you might consider modifying one hole in your license plate, so that you can adjust it to compensate for the minor variance.
I wouldn't want to mess with the existing panel, and risk making it worse without dealer involvement.
A "factory" license plate frame is thin plastic, and should fit regardless of the screw length.
post #5 of 33 (permalink) Old 07-28-2016, 01:59 PM Thread Starter
Quoted: 17 Post(s)
Stevevillatoro,
The car is Silver if that's what you mean by matallic. The license plate frame is a brushed stainless steel and not plastic. The idea of adjusting the plate frame is good but it still doesn't answer the question if the placement can be can be moved up or down slightly on the panel. I could just move it up or down and put a small amount of silicon in the previous holes to prevent moisture if I knew the area that screws will take hold. I still don't have the answer that I'm looking for. What area on the rear panel will accept the screws?
Is there a built up area on the backside of the panel that is two inches by two inches or something like that? Will it accept the screws anywhere as long as it's close? Anyone have a picture of a removed rear panel? I sure don't want to keep adding a bunch of holes to my car only to find out the license plant won't hold on! This sucks!
Hartmn
Hartmn1 is offline
post #6 of 33 (permalink) Old 07-28-2016, 02:40 PM
Your clarification helps a lot.
But I can't imagine it being possible to move the plate more than a fraction of an inch without (1) exposing your blobs of filler, and/or (2) causing a compliance issue with the license plate lighting during night driving.
I'd simply modify the plate holes by the tiny amount needed to level it, and get longer screws if needed. And leave the hatch panel unscathed. Why complicate it?
post #7 of 33 (permalink) Old 07-28-2016, 04:02 PM
sokoloff's Avatar
Quoted: 181 Post(s)
I might suggest waiting until you take your car in for service and/or warranty work at the dealership if they are too far away for a trip just to fix the license plate. Live with it until then, but I'd sure go on written record of the problem and that you expect them to fix it. And don't listen to them when they tell you that you can fix it by letting the air out of the tires on the high side until the license plate is level.
Len
2014 EV
stevenvillatoro likes this.
sokoloff is offline
post #8 of 33 (permalink) Old 07-28-2016, 04:10 PM
Quoted: 78 Post(s)
Who drills the holes: the dealership or the manufacturer?
Can understand the OP's caution about further drilling.
When fixed/leveled, would the errant hole(s) be fully concealed by the license plate? If so, then a DIY fix might be easiest. However, if a filled hole(s) would be visible above the plate, then consider reaching out.
If it's the dealership who drilled, then they would have bent over backwards to fix it before the sale. Doubt they would've said "take it or leave it" if you pointed out the crooked plate before signing the purchase contract. You obviously didn't drill the holes, so there shouldn't be squabbling over who caused the crookedness after you drove off the lot.
Contact the dealership first with pictures, if a DIY fix will leave visible hole mark(s). Since they are located a long distance from you, then insist that they authorize you to have the work performed at your local smart service center with full reimbursement to you.
If it's the manufacturer who drilled, then contact smart USA. They could refer you to your local service smart center to have the work performed at no charge.
White Lightning is offline
post #9 of 33 (permalink) Old 07-28-2016, 05:01 PM
Quoted: 78 Post(s)
Good idea!
Name:	License Plate.png
post #10 of 33 (permalink) Old 07-28-2016, 06:04 PM
MB DNA's Avatar
Quoted: 958 Post(s)
MY15, new purchased from a smart Center?
Have you called the dealer or your salesperson? Pictures speak a thousand words and can support your case.
Sooner or later you may need to advise them of your issue/disappointment and I'd put the emphasis on SOONER.
MB DNA is online now
Human Verification
License plate GreatBigStuff Interior & Exterior 22 11-24-2011 01:13 AM
Need ideas for (license) plate. kickboxinggranny smart General Discussion 53 08-29-2010 07:26 PM
License Plate Wile E. Coyote smart General Discussion 67 08-29-2010 04:34 PM
Euro style license plate installed SunDiego smart Modifications 16 10-15-2008 01:26 PM
New Member license plate circusgurl New Members Area 7 06-06-2008 06:28 PM
