Noise when you first start the car - Smart Car of America Forums : Smart Car Forum
Old 02-01-2008, 07:05 AM   #1 (permalink)
eqwalker's Avatar
Ok. I know someone may have already mentioned what this was, but I wanted to run it by everyone.
When I first start my car in the morning, there is this loud noise (almost sounds like a warning buzzer, but it isn't) coming from the car for about 10 to 15 seconds, and then it shuts off. I am assuming it is some sort of electric motor or pump running. I'm a little concerned that it seems pretty loud. Could someone fill me in on what this is? Just trying to get educated with the car and know all the things about it. Thanks.
Old 02-01-2008, 07:11 AM   #2 (permalink)
When you start the car it begins emission control immediately and that is the buzzing you hear...nothing to be alarmed of. It's perfectly normal.
iwantmysmart is offline   Reply With Quote
Old 02-01-2008, 07:41 AM   #3 (permalink)
Are you referring to a fan to add air to the exhaust on cold start, Thanks.
Old 02-01-2008, 08:49 AM   #4 (permalink)
Yes. There is an air pump the blows air through the exhaust (not only on cold start) to clean out the exhaust when you first start the car.
Old 02-01-2008, 10:19 AM   #5 (permalink)
Fredvon4's Avatar
There are several pre conditions and self tests conducted just before start, right after start, and between 0 and 5 mph
You may or may not hear all of them...
As state above, there is the air pre charge to the exhaust catalyst
There is the Anti lock brake (ABS) system test that should cycle the brake pump and depending on the result it may do it again during initial roll.... if good then no light. This one usually is not loud enough to hear, but you might feel rapid pulses in the brake pedal for 1 to 3 seconds
Not a test or pre condition.... the Air Conditioner / Heater controls are vacuum actuated.. there is a vacuum reservoir that may loose it's vacuum overnight (usually in colder weather). In the hot cold and vents control system is a "Blend" door that will fall open if the vacuum is lost... On engine start, the reservoir's vacuum increases very fast and the "blend" door can slam shut making a startling noise.... if this happens at every motor start cycle, then you should have the AC / heater control system checked for vacuum leak(s)
The fuel tank is directly below driver and passengers seats and there is a electric pump inside it... if the fuel pressure in the injector rails leaked down after last stop, then on key to "run", or power on..the pump will cycle until pressure is up.. if the car motor is not running, you may or may not hear this normal activity
Under the dash is the Service Accessory Module (SAM) sometimes called a General Electronics Module (GEM) these usually have several small relays inside. As various systems are energized, you may or may not hear the normal relay clatter
Old 02-07-2008, 01:36 PM   #6 (permalink)
bumblebee's Avatar
I think it could also be the power steering fan that you're hearing.
bumblebee is offline   Reply With Quote
Old 02-11-2008, 10:12 PM   #7 (permalink)
Xanthus's Avatar
That was my assumption. I have not looked to see but I was willing to bet the "electric" power steering was actually just electricly pressurized hydraulics and that was the system presurizing.
Like I said that was only a guess.
Xanthus is offline   Reply With Quote
Old 02-13-2008, 06:26 AM   #8 (permalink)
bumblebee's Avatar
The MINI does that too and it's as loud as the smart. That's why I think it's the ps fan.
Old 02-13-2008, 07:53 AM   #9 (permalink)
I have the manual steering and I still hear the same sound you are describing on start up for about 10-15 seconds.
Old 02-21-2008, 03:15 PM   #10 (permalink)
This is definitely the air pump charging the exhaust system and reducing unburnt hydrocarbons when the engine is cold. Part of the Ultra-Low Emissions system.
prm1177 is offline   Reply With Quote
How does the car do on road noise? dokedennis smart Operation and Maintenance 16 10-30-2008 02:25 PM
jump start??? maxtraxduffy smart Operation and Maintenance 19 01-27-2008 10:26 AM
When did they start employing robots at Smart? KeyserSoze smart Reservations 6 01-12-2008 09:31 PM
Old Thread just new start point. Billc smart Reservations 6 12-02-2007 05:16 PM
