Originally Posted by jwight
The remote control has an operating range of approximately 50 ft (15 meters). This can fluctuate greatly as a consequence of local conditions (reflective or absorbing objects) and interference emitted by other radio transmission systems. Similarly, the operating range fluctuates in line with the direction from which the remote control is activated. To prevent theft, however, it is advisable to only unlock the vehicle when you are in close proximity to it.
Locking and unlocking from the outside
> Selective unlocking: Press button© on the key once. All turn signal lamps flash once.
The anti_theft warning system* is disarmed. The driver’s door and the fuel filler flap are unlocked.
• Global unlocking: Press button© on the key twice. All turn signal lamps flash once again. The passenger door and the tailgate
are unlocked in addition to the driver’s door and the fuel filler flap.
> Global locking: Press buttonª on the key.
With the doors, the tailgate(s), and the fuel filler flap closed the turn signal lamps flash three times.
The anti_theft warning system* is armed.
The indicator lamp on the central locking switch (page 85) flashes.
The interior and exterior1 lamps come on and then go out again after 12 seconds.
1 Vehicles with rain_light sensor* only.
one more case of the manual not answering the question
