Transmission Problems and Driving Style? - Page 4 - Smart Car of America Forums : Smart Car Forum
View Poll Results: Have you had a tranny problem and how do you drive your smart?
No Problems. 51 79.69%
Yes, Like its a race car but shifting my own gears 3 4.69%
Yes, Gently but shifting my own gears 1 1.56%
Yes, In "D" (drive) and I drive aggressively 2 3.13%
Yea, In "D" (drive) and gently 7 10.94%
Voters: 64. You may not vote on this poll
Old 06-30-2008, 05:45 PM   #31 (permalink)
dbatch1715's Avatar
Found this, maybe it will help some of you who are "on the fence" about the smart because of the transmission.
The Key to High Mileage: Understanding the Smart transmission - 451 smart fortwo
Best regards,
Darrell
dbatch1715 is offline   Reply With Quote
Old 06-30-2008, 08:21 PM   #32 (permalink)
Drive: Forfour
Does the US 451 gear stick able to shift + and - at D? Do you push it to a side so that in the course of +/- shifting it does not kick into N?
As for Softip and Softouch, in UK and Asia Pacific always associate the softip with the paddle shift or gear stick for manual shifting in M Mode, and Softouch being in Auto Mode. Think of Softip as Tiptronic ie manual shifting. Essentially there are the same thing except one in M and the other in A mode.
In previous Smart 4/2, 4/4, and Roadie, you can do Softip (M) and Softouch (A) from the gear stalk itself. The 4/2 and Roadie require you to press a button on the gear knob itself to chose between the 2 mode. And with car that equipped steering paddle softip, we can do the shifting without leaving the steering and you can activate Softip with the paddle shift or bump the gear stick to the left to shift between Softip or softouch mode.
Darell,
As for that lift and shift, it help a lot on the previous version Smart 4/2, 4/4, and Roadie for new owner. During the gear shift, the ECU continue to squirt the fuel and you can see the RPM needle maintain almost the same speed even during that momentarily of Neutral when the clutch is engaged prior shift. Doing the lift and then shift for 1st to 2nd gear help a lot to the new owner to get over that jerk feel. From 2nd to 3rd, its much lesser and almost undetectable until 6th even without lift off the gas pedal. Perhaps the acceleration rate is lesser between gears once we go above 3rd.
As for fuel efficiency, we get much better in Softip(M) mode than Softouch(A) mode.
Because we can manually upshift at lower rpm ie less than 2.5k rpm vs in A mode, the ECU is very trigger gear happy at low road speed that its only upshift at much higher rpm. Fun to drive but take more gas.
Jesse Malaysia is offline   Reply With Quote
Old 07-01-2008, 04:34 AM   #33 (permalink)
The Super Shoe
mdfortwoguy's Avatar
On the NA 451, when you want to use the softip functionality, you push the shift lever to the left, at which point it clicks into another detent allowing it to be pushed up and down for shifting.
Also, on the N/A 451, pulling the paddles has no effect unless the transmission is in the +/- gate.
Old 07-01-2008, 07:22 AM   #34 (permalink)
Best regards,
Darrell
The dealer sales folks should all read this.
problems
Grand Style Smart car in Las Vegas michaelssm New Members Area 2 09-10-2008 07:36 PM
Smart Car Soprano Style vanslam smart Videos 1 03-17-2008 04:32 PM
Smart Mods Chinese style Fredvon4 smart Modifications 7 01-26-2008 05:17 PM
Let the Scalping Begin - Portland Style Iceberg smart General Discussion 12 01-18-2008 07:26 PM
Smart Mods German style Fredvon4 smart Modifications 15 01-18-2008 02:09 PM
