2009 Brabus Smart - Options Confirmed! - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Community > smart News & Rumors
Trailer
Old 11-21-2008, 05:15 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
tbone28's Avatar
I noticed that some of the options on the Brabus Smart that debuted at the LA Auto Show ( LA 2008: Brabus smart fortwo revealed - AutoblogGreen and for you Silver Brabus owners: http://allcarsallthetime.blogspot.co...otography.html) were different than the option list which Smart USA emailed us.
I decided to call Smart to confirm the options. The lady I spoke with said that our Brabus Smarts will be exactly as seen in the pics above.
Some differences:
1) Wheels - we get newly designed Monoblock VII's (not Monobloc VI's)
2) Wheel sizes - We will get 15" fronts/17" rears. My configuration email stated that we would get 16" fronts/17" rears. I'm a bit disappointed by the 15" fronts. The proportion to the rear doesn't look right to me. Hopefully, Brabus will make a 17" for a front application, and I will buy it.
3) Gear Shift knob - We get a Brabus-engraved "B". There was no mention of a special shift knob in my initial emails from Smart. This is a pleasant surprise
4) Brabus E-brake lever - Again a pleasant surprise. I thought we were not getting a Brabus one. Notice this lever is not the 100% brushed metal look that you can buy online. I do like the brushed metal look better, but I think our brake lever will be more unique
My wish list:
- I wish our Brabus came with the Brabus headlights
- I wish our Brabus came with the Brabus speedo and tach/clock combo
- I wish our Brabus came with the Brabus steering wheel
- I wish the Brabus suspension lowered the car more than it does (I will switch over to a coilover set-up once one is available for the 451)
- I wish MY BRABUS gets delivered in January
Old 11-21-2008, 05:35 PM   #2 (permalink)
thanks for posting! I think we might actually go to the show for this. We ordered the black on black.
So 15 front, 17 rear seems way too much understeer.
Old 11-22-2008, 06:54 AM   #3 (permalink)
Supporting Tuner
Evilution's Avatar
The diameter has almost no relevance to grip, it is the width of the wheel and therefore the contact patch of the tyre.
I would be surprised if it did have 15 front and 17 rear as that sort of jump has never been seen on a smart before, usually it's only 1" difference. Unless of course it is to get around your strict emissions laws.
I still think you are getting ripped off.
__________________
Old 11-22-2008, 10:55 AM   #4 (permalink)
evil,
they are 15s in front. here's the official data from the cd they gave to me
2009 smart fortwo BRABUS Technical Data
Engine
Displacement 1 liter / 61 cubic inch
Number of cylinders/ configuration three in-line
Engine block/cylinder head aluminum
Valves four per cylinder
Engine capacity 61 cubic inch
Bore x stroke 2.83 x 3.22 inches
Rated output 52 kW / 70 hp @ 5800 rpms
Max. torque 68 lb ft @ 4500
Oil 3.5 qt (including filter)
Coolant 4.5 qt
Fuel delivery electronic multipoint injection
Recommended fuel premium unleaded gasoline (minimum 91 octane)
Federal emissions BIN5 / ULEV (Cal.)
Power transmission
Clutch single-plate dry clutch
Transmission automated manual five-speed transmission
Gear ratios:
1st (3.308)
2nd (1.913)
3rd (1.258)
4th (0.943)
5th (0.707)
Reverse (3.231)
Final drive (4.529)
Running gear
Front axle suspension lower wishbone, McPherson springstrud, anti-roll bar
Rear axle suspension DeDion axle, coil springs, telescopic shock absorbers
Brake system dual-circuit brake system with tandem brake booster
11 inch diameter disc brakes at front
8 inch diameter drum brakes at rear
electronic stability program (esp®) with hill start assist
anti-lock braking system (abs®) with electronic brake-force distribution, traction control system, electronic brake assist
Steering power steering
Wheels and tires (front/rear) BRABUS “Monoblock VII” alloy wheels
all-season tires
175/55R15 (front), 215/35R17 (rear)
Dimensions and weights
Wheelbase 73.5 inches
Track width front/rear 50 inches/53.7 inches
Length 106.3 inches
Width 61.4 inches
Height 60.3 inches
Headroom 39.7 inches
Legroom 41.2 inches
Shoulder room 48 inches
Hip room 45.4 inches
Passenger volume 45.4 cu. ft.
Turning circle 28.7 ft
Luggage compartment capacity 7.8 (up to beltline)/12 (to roof) cu. ft.
ECE weight without driver 1,852 lbs (cabriolet: 1,896 lbs)
ECE Payload 485 lbs (cabriolet: 441 lbs)
ECE permissible maximum weight 2,315 lbs
Fuel tank capacity (reserve) 8.7 gal (includes 1.3 gallon reserve)
Performance
Maximum speed 90 mph
Acceleration 0–60 mph 12.8 sec
Fuel consumption
City/highway (mpg) 33/41 (EPA 2009)
Ack! That options matrix didn't copy and paste well. You can check it out here.
http://allcarsallthetime.blogspot.co...tures-and.html
rwcmick is offline   Reply With Quote
Old 11-22-2008, 10:57 AM   #5 (permalink)
more press release stuff:
LOS ANGELES (Nov. 20, 2008) – smart USA Distributor LLC, a subsidiary of Penske Automotive Group, Inc. (NYSE: PAG), today introduced the new 2009 smart fortwo BRABUS edition during the LA Auto Show at the Los Angeles Convention Center.
“Building on the success of the smart fortwo in the United States, we are excited to take the smart brand to a new level by introducing the BRABUS model and BRABUS accessories to smart fortwo enthusiasts,” said Dave Schembri, president of smart USA. “This car has always been about personal expression, and as we approach our first anniversary of sales in the United States, BRABUS adds a new dimension, extending our brand into new areas of customization and personalization.”
The smart fortwo BRABUS edition builds on the revolutionary smart fortwo design with a model that enhances the vehicle’s performance and styling. BRABUS is world renowned for providing exclusivity on wheels, and the smart fortwo BRABUS lives up to the expectations by offering exclusive design elements in a sportier package that maintains the fortwo’s hallmark fuel efficiency, fun and functionality. Drivers can choose between two BRABUS models that best suit their personal taste and lifestyle – the smart fortwo BRABUS coupe or smart fortwo BRABUS cabriolet.
The smart fortwo BRABUS is the first vehicle offered in the United States from a partnership between smart and the German tuning specialist BRABUS. The smart fortwo BRABUS will have a limited production run in early 2009.
Enhanced Handling
Building on the existing smart fortwo platform, the smart BRABUS has been tailored for enhanced appearance and handling. A sportier exhaust tuning along with a sports chassis and suspension components have been designed to offer a smooth ride and added comfort. The vehicle’s body has also been lowered by 10 millimeters to enhance the appearance and handling of the vehicle.
The BRABUS is powered by the same state-of-the-art, compact, three-cylinder gasoline engine as the current fortwo that has a capacity of 61 cubic inches, producing an output of 70 hp (52 kW). The vehicle’s five-speed automated manual transmission has been tuned for improved shifting, especially in the stop-and-go traffic of urban driving.
The Exterior – Aggressive and Sporty
The BRABUS enhances the fortwo’s exterior appearance with exclusive design elements that are unique to the brand. The vehicle’s BRABUS “Monoblock VII” alloy wheels measure 15 inches in the front and 17 inches in the rear. With one glance at the smart fortwo BRABUS, onlookers can clearly see the fortwo has developed a bold and sporty character and is proud to flex its muscles.
A striking double “B” BRABUS emblem proudly accentuates the fuel fill door and the BRABUS name is spelled out on the front and rear of the vehicle. The BRABUS front skirt reduces the front axle lift force to improve the driving experience and comes equipped with BRABUS side skirts that add a sporty appearance to the tridion safety cell.
To accommodate the BRABUS sport exhaust system, the rear skirt of the BRABUS model has a cutout in the center to accommodate dual chrome-plated tail pipes.
Consumers are able to match their BRABUS model to their choice of lifestyle by selecting between the “open air” cabriolet with a fully automatic convertible top or a coupe with a panoramic roof. The vehicle is available in two colors: metallic silver and deep black. The metallic silver comes with a metallic silver tridion safety cell, and the deep black with a deep black tridion safety cell.
To complete the exterior’s aggressive look, the BRABUS features halogen projector beam headlights, side indicators in yellow, and exterior mirror trim matching the tridion safety cell.
The Interior – Best to the Last Detail
The BRABUS model has sports pedals made of brushed aluminum. The vehicle features stylish velour floor mats embroidered with the BRABUS logo to accentuate the overall look and feel of the vehicle. The vehicle also comes standard with heated leather seats, power steering and additional dashboard instruments (all are options on the standard smart fortwo).
Each BRABUS model comes equipped with the same interior features of the standard smart fortwo passion coupe including: a single-disc CD radio that includes two speakers and an auxiliary input jack in the coupe model, or a premium six-disc MP3 compatible radio with sound system in the cabriolet model, molded storage areas located in the dash, door nets, along with a lockable glove compartment and storage areas beside the steering wheel. Also, a flat-folding passenger seat with backrest adjustment, coin holder (coupe only), dome light and mirror in the passenger sun visor.
Safety Comes Standard
Keeping with the benchmark set with the original smart fortwo, the smart fortwo BRABUS is designed with the highest level of safety and technology. Full-size airbags for the driver and passenger, along with head and neck side airbags are standard along with belt tensioners and belt-force limiters, which provide greater protection in case of a frontal impact collision.
Electronic stability program (esp®) is a safety feature instrumental in avoiding crashes (according to the Insurance Institute for Highway Safety), which is why all smart models come standard with esp®. The vehicle also features four airbags and many other advanced safety technologies typically found on premium vehicles, including hill start assist, anti-lock braking system (abs) and a hydraulic dual-circuit break system. The vehicle also features integral safety seats, drive lock, top tether for child restraint systems, panic button on the key fob, tire pressure monitoring system and a tire repair kit.
Both the Insurance Institute for Highway Safety (IIHS) and the National Highway Traffic Safety
Administration (NHTSA) performed crash tests on the smart fortwo. The IIHS gave the smart fortwo coupe a “good” (highest possible rating) for Frontal Offset Crash and Side Crash. NHTSA gave the smart fortwo 5 stars (out of a possible 5 stars) for side impact protection. For complete crash test results and to watch a video of the actual crash test visit smart USA - open your mind to the car that challenges the status quo. Crash tests were performed on the 2008 smart fortwo models.
Environmentally Friendly
The BRABUS model maintains smart’s commitment to the environment with excellent fuel economy and low vehicle emissions. The smart fortwo is the most fuel efficient, non-hybrid vehicle in the United States and fifth overall behind four hybrid models according to the U.S. Environmental Protection Agency’s 2009 Fuel Economy Guide. The vehicle achieves an average of 41 miles to the gallon on the highway according to the 2009 EPA regulations.
The vehicle already exceeds the goal set by Congress for the vehicle fleet and is classified as an Ultra-Low Emission Vehicle by the California Air Resources Board (CARB). It is also certified by the EPA as a “Smartway” vehicle, which indicates good environmental performance, placing it among the greenest vehicles on the market.
The ecology of the smart fortwo extends into its component materials and the manufacturing processes used to produce it. Up to ninety-five percent of the vehicle is recyclable, and the dash material is made from recycled synthetics. In addition, the “smartville” factory in France, where the vehicle is produced, is one of the most modern and environmentally friendly plants in the world.
BRABUS Sales Process
To build on smart USA’s successful and unique reservation program, smart created a similar, but separate, program to manage the sale of the BRABUS model. Current smart fortwo reservation holders have the exclusive opportunity to purchase the 2009 smart fortwo BRABUS with the option to convert their current reservation of a 2009 smart fortwo to the BRABUS. Customer response has been tremendous as many reservation holders opted for a BRABUS model.
The 2009 smart fortwo BRABUS coupe starts at $17,990*, manufacturer’s suggested retail price (MSRP). The BRABUS cabriolet starts at $20,990*.
*Prices for 2009 models. Prices exclude tax, title, registration, destination charge, options and dealer fees.
BRABUS Accessories
smart enthusiasts don’t have to buy the BRABUS model to enjoy the exclusivity and excitement the BRABUS brand has to offer. Beginning in 2009, smart centers across the country will begin offering BRABUS accessories for sale and installation on any smart fortwo model.
smart fortwo BRABUS accessories include:
Exterior
• Signature single color exterior panels and skirts (note – panels come primed and ready for painting for consumer color choice)
• BRABUS kit (includes: 15 and 17 inch BRABUS “Monoblock VII” alloy wheels, BRABUS sport suspension, exhaust and lower skirts)
• BRABUS sport suspension
• BRABUS sports exhaust system featuring chromed dual exhaust tailpipes with BRABUS rear skirt
• BRABUS rear skirt
• BRABUS front skirt
• Fender flairs
• BRABUS “B” design sticker on the fuel filler door
• BRABUS roof spoiler
• BRABUS grille and rear bumper BRABUS nameplates
• BRABUS double fog and driving lamps
• Light package available for side skirts
Interior
• Ambient lighting package that includes illuminated driver and passenger side foot wells and automatic on/off capabilities
• Leather-wrapped handbrake lever with embedded matte brushed aluminum BRABUS plate and leather-effect sleeve
• Leather-wrapped gear knob with embossed BRABUS logo complemented with silver release button
• BRABUS sport brake and gas pedals
• BRABUS velour floor mats
• BRABUS 3-spoke leather sports steering wheel.
A complete list of BRABUS accessories and prices can be found at smart USA - open your mind to the car that challenges the status quo.
Old 11-22-2008, 11:00 AM   #6 (permalink)
take note in the release above, there is a nice list of accessories that any smart enthusiast can buy
Old 11-22-2008, 11:54 AM   #7 (permalink)
Yes Kane, I am with you on the ripped off part.
We had a glimpse of the smart Brabus at the show last night. It's primarily my wife's car and she's utterly disappointed. From the driver's seat pov, it look exactly the same as a our current smart. You would think that they will at least use Brabus gauge pod face plates, some Brabus paddle-shifters Nope. The leather B-logo gear knob is a bloody joke as well. The seats should have at least a B-logo embossed as well. Nothing.
Regardless, I still find the 15/17 combo extremely awkward from every angle. I am already thinking of swapping them out to Rials 15s all round. Or maybe she will just sell the smart Brabus when it arrives.
Old 11-22-2008, 01:45 PM   #8 (permalink)
tbone28's Avatar
I think it is a rip-off depending on your point of view.
If you are looking for an authentic Brabus, then yes, you are getting ripped off.
If you are looking from a pure financial stand point, then it is a good deal - this is my perspective. i.e. if you price out a Brabus body kit, brabus suspension, brabus wheels, and the other cosmetic items, and then compare the price of a similary optioned Passion, you are getting a good deal. The difference in price of a similary priced Passion coupe and the Brabus is just under $3000. Retail price on all the mods is quite a bit more.
Old 11-24-2008, 09:30 AM   #9 (permalink)
09' Silver Brabus!
just_johnny's Avatar
I agree with tbone28. I was going to do a body kit, wheels, and exhaust upgrades anyway but now it's all there, plus it's painted at the factory. The body kit would have to be painted which is additional money being spent.
just_johnny is offline   Reply With Quote
Old 11-24-2008, 12:15 PM   #10 (permalink)
bottlerocket's Avatar
I'm with you however I hope to go get a look for myself sometime this week to help me make up my mind.
bottlerocket is offline   Reply With Quote
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f3/2009-brabus-smart-options-confirmed-16777/
SMART CAR PICTURES This thread Refback 11-21-2008 07:29 PM
2009 BRABUS announcement BobTheMad smart News & Rumors 188 01-09-2009 12:36 AM
2009 Brabus smart fortwo Configuration ShaneXman smart News & Rumors 165 11-20-2008 12:38 PM
2009 Options and Colors liquidfunk smart General Discussion 24 11-10-2008 08:27 AM
2009 Accessory Options ? tmaromine smart News & Rumors 6 07-24-2008 06:42 AM
Smart : Brabus Fortwo CDi Brabus Wide Star Smart Fortwo CDi Cabrio "Quick Silver" Smart Cars For Sale Archive/obsolete (?) threads 0 05-16-2008 12:30 AM
