'Orphan' Smart cars pile up as buyers back out - Page 6 - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Community > smart News & Rumors
Old 07-04-2009, 08:11 PM   #51 (permalink)
Macaw's Avatar
Originally Posted by deltadart View Post
And what "multiple visits to a shop for a conventional automatic transmission" are you talking about? There are quite a few cars that have sealed transmissions that require very few ATF changes.
I believe the early New Beetle's would fit that description as they had probably one of the worst "sealed" transmissions that died like flies, even with only 50k miles or less on them....note I had one of these POS's
Old 07-04-2009, 09:39 PM   #52 (permalink)
It's hard to argue with a 10 year/100,000 mile warranty on the engine/transmission even though they usually don't break. That's still lightyears better than the Smart unless they have change the 24K mile warranty. And what "multiple visits to a shop for a conventional automatic transmission" are you talking about? There are quite a few cars that have sealed transmissions that require very few ATF changes.
My point was that those 100,000 mile warranties are not free with the car. The car companies simply got sick of all of the aftermarket companies eating up the profit margins. So the car companies simply raised the price of the car and said it's included.
Smart could do the same thing. Instead of selling the car for $14,900 with a 24-month/24,000 mile warranty, they could simply raise the price to $16,400 and make it a 60-month/100,000 mile warranty. You can do it yourself by buying the car and buying an extended warranty.
Smart made that low warranty to keep costs down, plain and simple.
I doubt any person could not drive a new smart 100,000 miles and not have the engine throw a rod or blow the transmission. That car has a manual transmission and those things last forever if you change the gear lube regularly if you decide to use the cheap gear lubes in the auto part stores.
When I say multiple visits, you are supposed to change the transmission fluid about every 30,000 miles. So by the time you hit 100,000 miles on most 4-cylinder cars, you have had to pay all that money to change the transmission fluid 3 times and do a timing belt.
With the smart, I would simply go about 7,000 miles to let the transmission break in good and then I would go with the Amsoil 75W90 gear oil which lasts 100,000 miles. Since the smart has a timing chain, that's one less expense you have to mess with.
This car is so dirt cheap to own, it's not even funny. But if you keep bringing it back to smart or Mercedes for your oil changes, you're not going to save any money and the maintenance will cost you much, much more than owning something like a Honda Fit or Toyota Yaris with an automatic transmission.
Many people neglect the automatic transmission. They drive it until it starts having problems and then they finally break down and spend the money on a transmission flush. By then, it's too late. The damage is done and the transmission then needs to be overhauled.
I always avoid those problems altogether. I do preventative maintenance all the time and never spend a dime on rebuilding an automatic transmission or engine. My cars always run like new for the entire time I own them, no matter how many miles I put on them. I would expect the same with a smart car.
Smart should warn all customers about the short-comings of this car so that the people don't buy the car, put 5,000 miles on it and then try to sell them right away. The dealers have a hard enough time trying to unload their inventory without having thousands of people compete with them trying to unload almost-like-new smart cars.
I bet you that many people buy the smart car and have no idea what it will cost to go back and get the car maintained at smart or Mercedes. Then when they go back, they get sticker shock, like the local place here told me the oil change for the smart was over $230 bucks!
Thank god I am not that lazy. I don't mind backing the car up on some ramps and change the oil myself. It's not all that difficult to do. The differential on the transmission may be the little tricky part. You will have to run a hose down with a funnel passed through from the engine compartment. I was told that it only takes 3-1/2 quarts. That's like $40 bucks worth of fluid and you're done. With a conventional automatic, you need to add above and beyond what the transmission takes so that the torque converter can be flushed out with the old fluid in it. This is why I LOVE manual transmissions so much. Easy maintenance and they last forever. I don't mind shifting in traffic.
homeslice is offline   Reply With Quote
Old 07-04-2009, 09:42 PM   #53 (permalink)
The transmissions are not sealed. They simply stopped adding dipsticks. They don't want consumers messing with it. You're supposed to bring it to a shop and have the transmission connecting to a flushing machine. It pumps in 9 to 14 quarts and pumps out the exact same amount.
I would just rather try to buy cars with manual transmissions. Automatics are too prone to expensive repairs when not properly maintained. That's why I am scared to death to buy a used car. The transmissions are usually the first thing to go. You can put a million miles on a manual transmission. Just change the clutch and pressure plate every couple hundred thousand and the car is like new.
Old 07-08-2009, 03:59 PM   #54 (permalink)
Missing the forest for the trees...
The only problem with that position is that not everyone is manual transmission friendly. Use of a clutch is not taught in driver's education any longer (and has not been since the early 1960's where we have lived), and many who end up with manual transmission vehicles don't have much of a clue as to how to start on hills, how to "slip the clutch", and how to properly shift when on the move.
I preferred a manual transmission up to the point where I got some serious damage to my left leg during the late RVN conflict. At that point, my nifty Opel GT went from an asset to a liability in a hurry. I off loaded that one for an automatic transmission, and haven't looked back since.
Now, as I approach 60 (and as my wife approaches 70), the last thing that we want is a car where our legs have to push against clutch springs. The last hurdle (well, the last "suitability hurdle") between us and the Smart car was the suitability of the "semi-automatic" transmission. Once we found how well it worked, and how well the booster made it work beyond that, we green-lighted the sale subject to the working installation of a trailer hitch on the Scion xB (which we also love).
As for orphan status, you have to remember that the media (all of it, right down to the local Greensheet shopper paper) is looking for content that will sell ad views. The greater the controversy, the greater the interest - hence the "Inventory is piling up!" line being taken by the staff writers.
From the outside looking in, it's easy to ignore the tremendous pressures placed on anyone writing for any publication. They publish to deadlines, and in many cases have to come up with their own stories. Then too, the natural tendency of schandenfreund to put the sell on any article means that anything negative is much more "salable" than is the corresponding positive, particularly if the positive version has already been written.
Thus, "They are happily married" (when talking about Billy Bob and Angelina) works up front, but once it's been used, the natural salable sequel is going to be "They hate each other," not "They still love each other."
As for the glitteratti, so too for any other story, be it pork bellies or Smart cars.
Terry Stibal is offline   Reply With Quote
Old 07-08-2009, 04:17 PM   #55 (permalink)
smark's Avatar
Every new car dealer here, has cars back up to there eyeballs. 300 some Honda's on the lot. Fast selling Fits just sitting there. Hyundai's dealers lot, is like looking at a port of entry. Nissan's cars out the butt. Same with the Smart dealer too. Got to be 25-30 cars there too. It has nothing to do with the little car. Things are still very bad. People are still loosing there jobs. At work we just lost out whole 3-D digital department, last week. They let good people go, or made them take early retirement. Money is tight, if you have a job.
Old 07-08-2009, 04:40 PM   #56 (permalink)
Yep... 476,000+ people lost their job in June 2009. Makes it hard to buy a new car.
Yes, Terry, that makes absolute sense for driving an automatic in your case. But most people don't have that issue. Go to South America and 99% of the cars there are manual. And that place is very hilly. I asked people there why they don't have automatics. The reply: "It's too expensive."
That's exactly why I don't want an automatic. It's not so expensive to buy when the car is new, it's once the car has over 100,000 miles. A person should not be forced to constantly trade out of a perfectly good car because of a faulty transmission. Cars should last a good 500,000 miles before you dump them.
Yeah, I've been to a couple smart dealers and the lots were completely full of fortwo's. I just came back from the Honda dealer about 20 minutes ago and at least they had a bunch of customers there. When I was at the smart dealers, I didn't see one single customer in the past 4 or 5 visits to the smart dealer. NONE. ZERO. ZIP!
I just hope things improve. I would love to see more and more of the smarts on the road.
Old 07-08-2009, 07:47 PM   #57 (permalink)
I think the smarts will make a comeback. Just wait until the economy picks up again and the demand for gas and oil pick up. With the cutbacks that have been made by OPEC and oil companies here in the States, mainly in the Gulf area, gas will take a jump. Some who are in the markets are saying we could be seeing $6 gas if demand increases before the supply picks up again. As always, only time will tell.
Don't forget all of the added taxes that Congress is talking about too. If they succeed and approve the Cap and Trade rules they are talking about, gas prices, food prices, you name it, will increase. People will find a smart as the only vehicle they can afford to drive!
And then there's hurricane season too...
PhilWinIL is offline   Reply With Quote
Old 07-08-2009, 08:07 PM   #58 (permalink)
Dude, when gas hits $6/gallon, you won't find a hybrid or smart car on any dealer's lots.
Everybody thinks I am nuts to buy this car. Those are the same people who have never been on Peak Oil News
We will see who has the last laugh when all of those people are crying that they can't afford $150 to put gas in their SUV's for a week's worth of driving.
Old 07-08-2009, 08:14 PM   #59 (permalink)
Godfather's Avatar
What am I missing here? It takes about $18 to fill my smart. It takes about $45 to fill the wife's mini-handicap van. What's not to love, right NOW, about the smart? All I know for sure is this.... it's warm out again, and the questions never stop......
Old 07-08-2009, 09:01 PM   #60 (permalink)
Now THAT'S WHAT I'M TALKIN' ABOUT!!!!
That's why I want that car so bad!!! I WANT TO DRIVE THE PISS OUT OF THAT THING and go everywhere and rack up HUNDREDS of thousands of miles on it and do is SOOOOOOOOOOOOO CHEAPLY!!! And thumb my nose at all of the people paying big bucks for gas.
The smart car RULES!!!!!!
Buyers remorse after trading to small cars... vwW12 The Car Lounge 6 11-08-2008 09:11 AM
Any Orphan Buyers in NY/NJ/CT NOT pay for add-ons? jmatero smart General Discussion 9 05-18-2008 02:55 PM
Just got back from Minneapolis Auto show - NO smart cars. WTF! mnext02 smart General Discussion 7 03-22-2008 05:27 PM
Bad credit smart buyers. jediknight36 smart General Discussion 5 02-01-2008 04:13 PM
