Originally Posted by lhoboy
Has anyone seen the specs on compression ratio? I suspect it's high to get the 71hp/1000cc, and hence the need for higher octane.
Because I recently posted a response to it. I think it was with regard to the Brabus and the turbo it has making 86hp and the normally aspirated 71 hp engine having a higher compression ration due to it not having the added power created by turbo. I think the Brabus with 86 hp has 10:1 compression and the US model has 11.4:1. You would think that would be the other way around but as my memory can recall, the use of a turbo at the higher compression ratio of 11.4 may compromise the integrity of the engines lower end perhaps so they lowered that to be able to gain the benefits of the turbo. Not sure about this but it makes sense to me with my knowledge of engine design/building.
Fish will know for sure as he wrote the original post that I responded to.
