Oil Change Video - Smart Car of America Forums : Smart Car Forum
Go Back   Smart Car of America Forums : Smart Car Forum > Media Center > smart Videos
Old 03-27-2008, 08:17 AM   #1 (permalink)
greatsign1's Avatar
Oil Change Video
I would really appreciate if someone could make a video showing how to change the oil in a 451.
Any other maintenance videos would also be greatly appreciated!
greatsign1 is offline   Reply With Quote
Old 03-27-2008, 08:40 AM   #2 (permalink)
I am wondering if there is something special about lifting the car. I am taking mine to a Mercedes dealership on Monday for an oil change.
Can something break under there if lifted wrong?
Meaux
Old 03-27-2008, 08:46 AM   #3 (permalink)
vanslam's Avatar
Actually I was able to get access to the oil filter and oil pan nut with out even lifting the car.
vanslam is offline   Reply With Quote
Old 03-27-2008, 08:53 AM   #4 (permalink)
Senior Smartie
jonnysan's Avatar
YUP...no need to lift it up...
But to answer your question, Meaux, yes you can damage things if you jack in the wrong place. In the rear, jack on the ends of the DeDion tube. That's that 3" diameter metal tube facing rearwards (just inside the wheel) as you look under the car. Ofcourse, if removing a wheel, place a jackstand under that bar just forward of where you are jacking. Not sure about where to jack on the front but generally you want to find a frame point or someplace on the suspension that's solid and that leaves you a place to put a jackstand for safety.
I would say if all else fails, consult the owners manual and see where they suggest to jack....;)
Old 03-27-2008, 09:06 AM   #5 (permalink)
Check this thread
http://smartcarofamerica.com/forums/...ead.php?t=4376
Mucho discussion of jacking points. For the oil change, you might just want to run the opposite side rear wheel up on a 2x6 or similar to allow the oil to flow toward the drain plug.
Old 03-27-2008, 12:47 PM   #6 (permalink)
Thank you everyone. I will bring this info with me. NOW, what about one of those thingies that they lift cars on in say....Mercedes dealerships??
Will tht hurt it?
Meaux
Old 03-27-2008, 08:06 PM   #7 (permalink)
Gortok's Avatar
If they break it, they have to fix it...
They'll know how to lift it.
Old 03-27-2008, 08:21 PM   #8 (permalink)
2mutch's Avatar
smart on a lift
The dealerships have 4-point lifts sized for the smarts. The lift arms are positionable under all four of the car's lift (jack) spots and 'up it goes.'
- FRED "2 MUTCH"
Is it a car? Is it a mind set? It's BOTH!
2mutch is offline   Reply With Quote
Old 03-27-2008, 08:25 PM   #9 (permalink)
2mutch's Avatar
Not video...but oil change images..
...from the first oil change performed at the Bloomington, MN smart center. Enjoy!
Here's a small image of the lift placed on the rear jack point. The flash makes the 'wintery dirt' look yellowish...
- FRED "2 MUTCH"
Old 03-27-2008, 08:27 PM   #10 (permalink)
2mutch's Avatar
Oil change image - from rear
- FRED "2 MUTCH"
Oil Change anthonype3 smart Operation and Maintenance 42 03-28-2008 10:09 AM
Change of Avitar Old smart The Car Lounge 6 01-31-2008 06:21 AM
Do We Need to Change our Assumptions? janaugust smart News & Rumors 16 01-17-2008 10:53 PM
