Air injection switching valve location - Smart Car Forums
post #1 of 12 (permalink) Old 02-10-2012, 11:08 AM Thread Starter
Tango's Avatar
Quoted: 6 Post(s)
Code P2440 Secondary Air injection system switching valve stuck open Bank 1
2008 out of warranty.
Part is $32.00 Can anyone tell me where its located or has anyone done this valve changeout themselves?. Would appreciate any help anyone can offer in this regards. Thanks Skip Florida
Tango is offline
post #2 of 12 (permalink) Old 02-10-2012, 11:29 AM
Quoted: 68 Post(s)
jwight is offline
post #3 of 12 (permalink) Old 07-08-2012, 07:49 PM
GONE FOR GOOD...
WhiteNBlack08's Avatar
Quoted: 357 Post(s)
I figured I should reserect this thread instead of starting a new one. Got a check engine light yesterday. Turned out to be a P2440 fault. I had a spare valve sitting on the bench that I bought over a year ago, so I took the 5 minutes and changed it. No code since. I'll update if anything changes. Simple fix, and only $38 for the part. First non-warranty "repair" in 108K miles, not bad.
WhiteNBlack08 is offline
The Following User Says Thank You to WhiteNBlack08 For This Useful Post:
jwight (11-05-2012)
post #4 of 12 (permalink) Old 08-30-2012, 06:12 PM
Quoted: 28 Post(s)
Isn't it amazing it knows this little, unnecessary, plastic valve isn't working right but has no idea the main fuel pump isn't running from a blown fuse and the stupid engine has no fuel pressure? Pollution control gadgets are much more important than checking to see if it has fuel under pressure to run it.
larryw4csc is offline
post #5 of 12 (permalink) Old 08-30-2012, 06:38 PM
Quoted: 154 Post(s)
...quit your crying Larry and move on...
Jetfuel...know what I mean Vern?...
jetfuel is offline
The Following 2 Users Say Thank You to jetfuel For This Useful Post:
Rustedwrench (08-31-2012), SNAPHU (08-31-2012)
post #6 of 12 (permalink) Old 11-05-2012, 02:36 PM
donnyonee's Avatar
32 or 38 where?
donnyonee is offline
post #7 of 12 (permalink) Old 11-06-2012, 06:01 AM
Quoted: 84 Post(s)
Originally Posted by donnyonee View Post
32 or 38 where?
Genuine Electronic Air Intake Change Over Valve
chieftmc is offline
The Following User Says Thank You to chieftmc For This Useful Post:
jwight (11-06-2012)
post #8 of 12 (permalink) Old 11-06-2012, 06:18 AM
donnyonee's Avatar
thank you ordered this am
post #9 of 12 (permalink) Old 11-07-2012, 01:36 PM
donnyonee's Avatar
received and installed today, $38 total
mercedes wantwed 373 for that fix plus they measured 1 tire at 3mm and the rest at 4mm, so 4 tires was 900+ and alignment for 150, total 1300+. pass on that.
post #10 of 12 (permalink) Old 12-06-2012, 11:43 AM
p2440
I have a p2440 code on my 08, I replaced the vacuum switching valve, reset the code, but it came back within 10 min. any thoughts?
bender461 is offline
Human Verification
331
P0410 Check Engine Error Code, Secondary Air Injection System Fault paulmorr smart Operation and Maintenance 50 11-15-2016 07:37 PM
P0410 Secondary Air Injection System Malfunction NY Smartie smart Operation and Maintenance 94 04-01-2015 01:52 PM
Purge valve location 2003 gray market?? desertpagoda Modifications and Repairs 5 02-22-2012 07:49 PM
PCV valve location bluedeuce smart Operation and Maintenance 1 12-05-2011 09:47 AM
Question RE: secondary air injection pump gurps smart Modifications 18 06-09-2011 08:35 PM
