Fuel tank over-fill: symptoms - Smart Car Forums
post #1 of 30 (permalink) Old 08-03-2010, 11:15 AM Thread Starter
Yesterday, I think I experienced the symptoms of an over-filled fuel tank.
I try to follow the recommendations: use the auto shut off pumps, don't top off the tank manually.
I think I inadvertently overfilled the system.
Here are the symptoms I experienced:
1. hard bucking gear changes, in both the auto and the manual mode
2. strange revs- take foot off the gas, and tach revs don't fall as normal, the revs seem to "pulse" up and down. revs eventually drop off, but not like normal...higher than normal idle speed (according to scanguage)...
3. unexpected stall at a red light (never had a stall, ever)
4. no engine warning lights, no other dash indicators
later in the evening, after about 20 miles of driving, and a period of parking, all these symptoms seemed to disappear...vanish...the car now behaves normally.
what do you all think?
does it sound like I experienced an overfill?
theguywiththelongestname is offline
post #2 of 30 (permalink) Old 08-03-2010, 12:07 PM
sheureka's Avatar
I've had it happen once and it sounds a lot like my experience. I was driving to San Diego and stopped outside of Yuma for gas and before I realized it there was gasoline everywhere. When I started the car up it bucked and burbled and sputtered for nearly 50 miles. It felt a little like it was running on only one cylinder. And I'm in those hot, desolate, mountains between Yuma and El Cajon in July! But once it had cleared out it was fine again.
My guess is that's exactly what happened to you. - sheureka
sheureka is offline
post #3 of 30 (permalink) Old 08-03-2010, 12:29 PM Thread Starter
Originally Posted by sheureka View Post
... When I started the car up it bucked and burbled and sputtered for nearly 50 miles. It felt a little like it was running on only one cylinder...
exactly! it felt like it was miss-firing, or had a clogged fuel line/filter..."burbled and sputtered"...bucking bronco! thanks for sharing...
post #4 of 30 (permalink) Old 08-03-2010, 08:27 PM
SmartDigger's Avatar
Quoted: 176 Post(s)
Sounds like vapor lock. it probably had to clear the venting level to let the fuel travel smoothly
SmartDigger is offline
post #5 of 30 (permalink) Old 08-03-2010, 08:31 PM
He's not mine
NCC1701's Avatar
Quoted: 355 Post(s)
At an unfamiliar station, pump ... I had a pump NOT cut off upon fill. I was distracted and actually didn't notice the fuel spilling on the ground for a few seconds. I reckon that would count as overfilled? I didn't have any symptoms, as you describe. Other than wasting gasoline, I had no ill effects.
NCC1701 is offline
post #6 of 30 (permalink) Old 08-22-2010, 11:53 AM
Guest
Quoted: 72 Post(s)
Yeah I just had that happen to me just yesterday. Pump did not turn off, splashing all over, almost $30 and over 10 gallons for the 1st time. Still no ill effects at all, even in 100% humidity.
-How come I got lucky and didn't end up like tgwtln and sheureka? Is it different fuel? different elevation? Maybe different humidity had something to do with it? I was in a Central Florida downpour where the temperature dropped within minutes from an even 100 to 73 (according to the dash)
Pee-wee Germa is offline
post #7 of 30 (permalink) Old 08-22-2010, 12:23 PM
chumly's Avatar
Quoted: 23 Post(s)
Your gas shrank!(shrunk),shrinked?! Got littler!
chumly is offline
post #8 of 30 (permalink) Old 08-22-2010, 04:11 PM
Quoted: 176 Post(s)
I think it will tolerate it once in a while.
post #9 of 30 (permalink) Old 08-24-2010, 01:31 PM
RussBarnes's Avatar
Quoted: 1 Post(s)
One other symptom. My rr, white powder painted rim has a greenish cast. And I used to overfill a lot, but haven't in a couple years. Never had any running issues.
RussBarnes is offline
post #10 of 30 (permalink) Old 08-24-2010, 02:09 PM
Quoted: 84 Post(s)
Where's that dog????
chieftmc is offline
Human Verification
331
Removal of fuel tank and fuel pump dhirtle Technical "stickies" 1 08-31-2015 05:13 PM
FAQ: Fuel Tank is 10.08 GALLONS... yes.. I took the tank out the car.. LOL LittoDeviL smart General Discussion 106 09-22-2013 04:38 PM
Not going there (cost to fill the tank) Karl Roth smart News & Rumors 17 04-12-2012 08:40 PM
Fuel gauge didn't fill up? ArcanaNoir smart General Discussion 3 02-15-2012 10:26 AM
Fuel Filter in tank? mashaj smart Operation and Maintenance 12 12-01-2009 02:20 PM
