Generic P0303 engine misfire - Smart Car Forums
 12Likes
post #1 of 73 (permalink) Old 11-21-2012, 06:46 AM Thread Starter
Have a 2011 with 30,000 miles, changed oil every 5000 miles, use Mobil1. Started getting P303 code setting at idle. Pulled plugs and looked, plug closest to drivers side had pretty good wear on electrode, others didn't have much. Replaced plugs and still get this code at idle. If you let it idle to long, engine light will flash. Still same code. It will reset and if I am careful and not idle more than a minute or so it will not come back. Hard to do in town. Anybody have any real good non-motor removing thoughts........................
msmurphree is offline
The Following User Says Thank You to msmurphree For This Useful Post:
westwrench (03-14-2013)
post #2 of 73 (permalink) Old 11-21-2012, 09:02 AM
elmosisu's Avatar
Quoted: 5 Post(s)
Injectors might be dirty. Have you run any cleaner through the fuel system ever? I would put a full can of Seafoam during your next fill and go for a long drive to see if that helps
elmosisu is offline
The Following User Says Thank You to elmosisu For This Useful Post:
post #3 of 73 (permalink) Old 11-21-2012, 10:32 AM
Quoted: 9 Post(s)
There's ample evidence on this forum to suggest that these engines are prone to excessive carbon buildup around the exhaust valves. Many have made a compelling arguement for periodic use of injector cleaner and regular if not exclusive fillups with top tier (with all the additives already in there) gas.
I plan to run 6 oz of Seafoam directly through the top end when we hit 30K. You might consider doing the same to give it a good cleansing.
dhirtle is offline
The Following User Says Thank You to dhirtle For This Useful Post:
post #4 of 73 (permalink) Old 11-21-2012, 11:03 AM
jefferios's Avatar
Quoted: 73 Post(s)
Seafoam might be your way to go. Is your car idling rough?
jefferios is offline
The Following User Says Thank You to jefferios For This Useful Post:
post #5 of 73 (permalink) Old 11-24-2012, 01:13 PM
Smart_NCG's Avatar
Im Having the same problem with mine. It keeps throwing a P0303 Code.
I Replaced the Spark plugs, Checked the filter, Swapped Coilpacks, Swapped Injectors and still getting the same code. The car idles rough but runs fine.
-Also add seafoam to a half tank
Smart_NCG is offline
The Following User Says Thank You to Smart_NCG For This Useful Post:
post #6 of 73 (permalink) Old 11-24-2012, 01:49 PM
He's not mine
NCC1701's Avatar
Quoted: 357 Post(s)
Spark plugs changed to Denso Iridium around 30K. I'm closing in on 54K at 52 months. Nearly all Chevron 93, a few Shells & Texacos* ... all top tier premium. So far, no sign of roughness or missing.
Is an injector cleaner needed at any time when using good premium grade gasoline? (With all the additives already in there).
* and a half dozen or so tanks of No Name Ethanol Free.
NCC1701 is offline
post #7 of 73 (permalink) Old 11-25-2012, 01:57 PM
Quoted: 9 Post(s)
many previous posts from people who replaced plugs with Iridiums and threw phantom misfire codes too - apparently the system is very sensitive to the gap - did you gap them before installation or just put them in out of the box?
as for the seafoam - I don't see a downside to using it every 10K miles as cheap insurance, like I said this engine seems to accumulate carbon on the exhaust valves, which may or may not have anything to do with a bunch of engines with worn out valve guides and compression issues at only 50K miles. any extra measures you take to keep the top end from gunking up with deposits seems like a safe bet.
dhirtle is offline
post #8 of 73 (permalink) Old 11-30-2012, 10:46 PM
Smart_NCG's Avatar
I Diagnosed the problem with my P0303 Code. My Smart would idle rough and after it would warm up, the car would Run on 2 Cylinders if i idled for more the 30 seconds. I Used a Light Noid on the 3rd Injector while it was misfiring and found it had no signal. Every time i reset the car it would start working again.
So after I traced the 3rd injector signal wire to the ECU and checked the Resistance with Injector 1 and 2 and found no signal problem.
This tells me that the ECU in malfunctioning some how. I'm hoping on Having a Star Diagnostic System hooked up to it by this weekend to see whats going on.
The Following 3 Users Say Thank You to Smart_NCG For This Useful Post:
chieftmc (12-03-2012), jwight (12-01-2012), PureSmarts (07-22-2013)
post #9 of 73 (permalink) Old 12-01-2012, 01:38 PM
Rustedwrench's Avatar
Quoted: 218 Post(s)
Some late-model engine control modules will turn off the injector driver to a cylinder on which a misfire is detected. This is done for emissions control reasons. I do not know whether the smart system does this. I mention it only to point out that what you are seeing may be the result of some other fault being detected, rather than the cause.
Rustedwrench is offline
post #10 of 73 (permalink) Old 12-03-2012, 07:26 AM
Quoted: 84 Post(s)
Please let us know what you find out
chieftmc is offline
Human Verification
Mitsubishi engine code #2 misfire greenek1 smart Operation and Maintenance 53 07-09-2016 05:16 AM
Stick a fork in it, she's done (P0303) jimvw57 smart Operation and Maintenance 30 11-04-2015 10:23 PM
Random engine misfire msmurphree smart Operation and Maintenance 10 01-15-2014 03:10 PM
Misfire mistyguchie smart General Discussion 7 02-09-2013 03:18 AM
Generic car maintenance tips jwight The Car Lounge 0 07-26-2011 08:59 AM
