MAP sensor on a 451 - Smart Car Forums
 1Likes
post #1 of 13 (permalink) Old 03-03-2014, 09:34 AM Thread Starter
Quoted: 2 Post(s)
MAP sensor on a 451
Where is it located? I got a "P0106/Manifold absolute pressure sensor" error code. Can't find any info about it on the 451 model out there.
copesettic is offline
post #2 of 13 (permalink) Old 03-03-2014, 01:20 PM
BARNEY O's Avatar
Quoted: 123 Post(s)
Its located on the front side of the engine mounted towards the bottom of the plastic intake manifold... The front side being closest to the cabin...
BARNEY O is offline
The Following 2 Users Say Thank You to BARNEY O For This Useful Post:
John8888 (07-14-2014), tablist180 (03-03-2014)
post #3 of 13 (permalink) Old 03-03-2014, 08:57 PM
SmartDigger's Avatar
Quoted: 176 Post(s)
Evilution - Smart Car Encyclopaedia this will get you all you need.
SmartDigger is offline
post #4 of 13 (permalink) Old 03-03-2014, 10:57 PM
BB Benz's Avatar
Quoted: 226 Post(s)
That would be true if we were talking about earlier smart cars with the MB Suprex engines.
The 451 that most of us have in the US has the Mitsubishi engine. Just to keep things from getting tangled or confused.
BB Benz is offline
post #5 of 13 (permalink) Old 03-10-2014, 08:09 AM Thread Starter
Quoted: 2 Post(s)
Is this accessible to the amateur mechanic? MB wants $600 to replace it, but it costs $170 for the part.
post #6 of 13 (permalink) Old 03-10-2014, 08:20 AM
Quoted: 68 Post(s)
1 Screw
2 Intake manifold
3 Electrical connector
B28 Intake manifold pressure sensor
ALLDATA says the engine needs to be lowered for access.....
jwight is offline
hihosilver (03-10-2014)
post #7 of 13 (permalink) Old 07-14-2014, 10:16 AM
Quoted: 2 Post(s)
Ive been trying tolocate this map sensor. I cant find it still. It isnt any where. So the engine has to be lowered. I wonder if I can get access to it removing the front seats
spottarget is offline
post #8 of 13 (permalink) Old 07-14-2014, 10:43 AM
BARNEY O's Avatar
Quoted: 123 Post(s)
No...
BARNEY O is offline
post #9 of 13 (permalink) Old 07-14-2014, 11:05 AM
Quoted: 2 Post(s)
So I guess I have to take it to the dealer to get replaced. Sucks
post #10 of 13 (permalink) Old 05-16-2015, 06:24 PM
Quoted: 4 Post(s)
fyi this map sensor can be replaced without removing the engine. You will need to use jack stands for both rear wheels, then get under the car, use a t-25 torx screw, unscrew the screw and remove sensor. I found it better to use a small ratchet, add a 1/4 socket and then a t-25 torx bit, use the wrench from the ac compressor side and use your right hand to hold the wrench in place. Good luck!
SimTek likes this.
smartcarnewbie is offline
The Following User Says Thank You to smartcarnewbie For This Useful Post:
jwight (05-17-2015)
Human Verification
331
MAP/IAT Sensor location and for use with the X3 Performance chip install.... 16.luca Arizona Chapter 5 12-20-2016 10:10 AM
Do we have a map. SOCAL SMARTIES MAP ADilwicius So Cal Smarties 46 06-05-2010 02:45 PM
One front 451 rim, tire & sensor complete $195.00 jgabram Archive/obsolete (?) threads 1 11-10-2008 05:24 AM
Smart Car of America Member Map - map is full! smorris New Members Area 140 07-07-2008 07:54 PM
How hard is it to install light sensor or rain sensor? lukerc smart Operation and Maintenance 1 06-05-2008 06:52 PM
