Rattling noise "only over 60 mph" - Smart Car Forums
post #1 of 32 (permalink) Old 06-24-2009, 12:49 PM Thread Starter
OTD2 lifetime Member
Monalis's Avatar
Quoted: 8 Post(s)
The other day Betty started making a racket, sounds like the radio console is loose or something is in the glove box rubbing against the plastic. (hope you know what I'm talking about)
Over the last couple of days I've tried to figure out what is causeing the noise and have yet to figure it out. So here are my observations in hopes someone has had the same problem, or something similar and can help me figure it out.
  • The noise starts exactly when I hit 60 mph and stops as soon as I dip below 60.
  • There seems to be nothing loose, at least pushing the differant "panels" doesn't cause the noise to stop.
  • Taking everything out of the glove box does not help
  • Turning off the AC doesn't help
  • Took all the CDs out of the player, didn't help.
  • It seems that at night the noise isn't there, but I'll have to pay closer attention tonight.
Betty is just over a month old, and has about 3,000 miles on her. It's been really hot durning the day, upper 90's to low 100's and a bit cooler at night, in the 80's.
So I wonder what part of my car could be making this noise only when it is really hot out and only when going above 60mph.
Please help, it is driving hubby crazy (when I let him drive)
Monalis is offline
post #2 of 32 (permalink) Old 06-24-2009, 01:11 PM
Supporting Vendor
Quoted: 6 Post(s)
It's possible one of the balance weights on a wheel came off and what you hear is the resonance coming from part of the screwed-together assembly.
Since it's only a month old, if the weight came off there should still be evidence it ws there. Take a look at your tires to see if there's anything that looks like the footprint of a missing weight. You should have weights on the wheels - almost never is a wheel balanced with no adjustment.
It's a bit extreme to need your wheels balanced when it's only a month old, but perhaps your Smart Center would take care of that for you (if you ask nicely) if you're up that direction anyway. Maybe you need an excuse to purchase Smart branded goodies!
John_H is offline
post #3 of 32 (permalink) Old 06-24-2009, 01:45 PM
Quoted: 154 Post(s)
...so..what happens after 60...louder?
...does your car bounces up/down at 60?
...does your car shimmy left/right at 60?
...is your "hood" properly engaged in the upper tracks of the body?
...what's for dinner?
jetfuel
jetfuel is offline
post #4 of 32 (permalink) Old 06-24-2009, 03:09 PM
My cabrio also "developed" a rattle. Turned out it was the passenger seat belt banging against the plastic. I just grab it and pull it out to place the metal portion on the seat and the rattle goes away.
slk230 is offline
post #5 of 32 (permalink) Old 06-24-2009, 03:11 PM Thread Starter
Monalis's Avatar
Quoted: 8 Post(s)
jetfuel
It stays the same up to about 75, haven't gone over that yet, as soon as I go below 60 it stops, just to start again as I hit 60.
Car doesn't have any additional movement, no bounces or pulling to the left or right, that I can tell. I'll pay closer attention on my way home to check alignment on the road.
Hood is properly engaged and latched
And I think it's apple & sage grilled pork chops, around 9pm central.
Monalis is offline
post #6 of 32 (permalink) Old 06-24-2009, 03:19 PM
Quoted: 154 Post(s)
...open the door and check the "flaps"(3ea) that secures the front fender to the inner body... see if they are loose....don't just trust your eyes...see if they can be moved with hand pressure...
....pasta primavera on this end...
jetfuel
jetfuel is offline
post #7 of 32 (permalink) Old 06-24-2009, 03:34 PM Thread Starter
Monalis's Avatar
Quoted: 8 Post(s)
I never even thought about the weights. But since it doesn't drift, that I'm aware of, I don't think its that. But I'll keep it in mind and check for drift on my way home tonight.
I wish it was that easy, but since both hubby and myself were in the car this weekend and still heard it. I don't think its the seat belt. But I will keep that in mind since I usually do drive alone.
jetfuel
I'll check those in a bit, when things slow down over here. I hope it's something simple.
.... mmmmm pasta
Monalis is offline
post #8 of 32 (permalink) Old 06-24-2009, 03:43 PM
Quoted: 154 Post(s)
..one more ...open the hood...make hubby check the fan housing...big black round coffe can looking thing on the passanger side of the car...again..see if it will move when hand pressure is applied...high speed/frequency vibration noises will drive anybody up a wall....
jetfuel
jetfuel is offline
post #9 of 32 (permalink) Old 06-24-2009, 03:45 PM
NeWave's Avatar
I've got a similar issue, but I'd call it more of a tapping for me. Anything above 45 and it starts tapping right near the drivers door.. somethings loose. Just don't know what... Good luck on figuring that out.
Grilled Cod with seasoned rice...
NeWave is offline
post #10 of 32 (permalink) Old 06-24-2009, 03:54 PM
Supporting Vendor
Quoted: 6 Post(s)
A wheel balance problem typically results in vibration, not drifting. Alignment problems - a separate issue - are what cause the car to drift.
To make sure it has to do with tire speed rather than engine RPM between 60 and 75, try changing gears to 4th gear (which is still below redline at the electronically limited 92mph). You can even check 3rd gear at 60mph though I didn't like holding my car at 65mph in 3rd gear up those hot California mountains coming over from Oregon; it'll do it, though. Your engine will automatically upshift if it's at redline so you can't blow your engine by kicking it into 3rd. I just don't like the noise.
John_H is offline
Human Verification
331
Rattling noise under car eqwalker smart fortwo (451 - US vehicle) 24 10-16-2015 04:55 PM
Air Conditioner: Loud "thunk" noise? bradgarbus smart Operation and Maintenance 18 06-21-2010 10:41 AM
I have a rattling noise from the back yuckmoon smart General Discussion 17 01-04-2009 03:19 AM
Advertising? There was a check box for "wraps" and "stickers" randombilly New Members Area 3 08-31-2008 02:49 AM
Need additional "SCOA" placards "skyzdlimit59" 2442 California Chapter 1 03-30-2008 09:37 AM
