Rough Idle and Running - Smart Car Forums
 2Likes
post #1 of 13 (permalink) Old 08-19-2014, 09:44 AM Thread Starter
Quoted: 1 Post(s)
I have a 2008 smart fortwo with a little over 120,000 miles. Recently, I received the P0300, P0302, P0303 codes. It idles and runs rough and has noticeably lost power. I replaced the battery yesterday and the ignition coil on cylinder 2 just the other day. I had begun to suspect the CPS but don't have a code showing that is bad. Any thoughts or suggestions?
mbiskie is offline
post #2 of 13 (permalink) Old 08-19-2014, 11:23 AM
BB Benz's Avatar
Quoted: 226 Post(s)
Time to get a compression test and leak down test performed, on the cylinders.
Brabus007 likes this.
BB Benz is offline
post #3 of 13 (permalink) Old 08-19-2014, 12:10 PM Thread Starter
Quoted: 1 Post(s)
oh dear... I was afraid of that. smart center only, I presume?
mbiskie is offline
post #4 of 13 (permalink) Old 08-19-2014, 12:19 PM
Quoted: 84 Post(s)
No, you can do it yourself or have a "competent" mechanic do it for you (good luck finding one )
It "could" be spark plugs, COP or head gasket....a leak down and compression test will reveal a lot.
chieftmc is offline
post #5 of 13 (permalink) Old 08-19-2014, 12:54 PM Thread Starter
Quoted: 1 Post(s)
Thanks for the insights! I did put in 3 fresh sparks plugs a week ago. The old ones were way improperly gapped! The trouble did start after that, and after driving through a very large puddle on my way to work. I will replace the CPS and if that fails, do the compression and leak down tests. A friend of mine is a mechanic.
mbiskie is offline
post #6 of 13 (permalink) Old 08-19-2014, 04:25 PM
sokoloff's Avatar
Quoted: 181 Post(s)
If the problem started after the spark plug change, I'd sure start there before throwing parts and money at it. Did you use the correct recommended spark plug or did you fall for the advertising hype some spark plug manufacturers put out? Lots of issues with poor running on some Mercedes models when the wrong supposedly better plug is installed.
Len
chieftmc likes this.
sokoloff is offline
post #7 of 13 (permalink) Old 08-20-2014, 05:01 AM Thread Starter
Quoted: 1 Post(s)
Sokoloff...yes I used the Bosch replacement plug for the change. Additional information:
1. Problem really started after driving through heavy standing water on the road.
2. when coming to a stop, it cant seem to find the throttle... if I drop it into neutral and rev the gas, it stays running decently.
3. At speed, it seems to run just fine.
4. Car wont stall out, however, if I don't take the actions in #2 , when I press the gas to go, it sputters and has a hard time coming up to speed.
5. Even when running, a slight vibration occurs randomly... like the engine isn't running quite as smoothly as it should or used to.
Thanks again, all!
mbiskie is offline
post #8 of 13 (permalink) Old 08-25-2014, 06:16 AM Thread Starter
Quoted: 1 Post(s)
Well, after changing out the Crankshaft position sensor, unplugging the battery before I even did it, hooked everything back up and its even WORSE! Pulled plugs on 2 and 3 and they are already burned on the electrode. Not wet or oily, just burned. Tried to start it this morning, it barely ran. Have to find a repair person local to Ocala Florida to get it towed to. It spat and sputtered and shook so badly, I barely backed out of my parking space and back in...died 3 times during that process.
UGH!!
mbiskie is offline
post #9 of 13 (permalink) Old 08-25-2014, 11:42 AM
Quoted: 34 Post(s)
My 2 cents but I've never had any success with Bosch plugs or sensors. Japanese engines in my experience like NGK plugs. I've tried other brands and I've had problem with miss firing, fouling, and not seating properly.
09451 is offline
post #10 of 13 (permalink) Old 08-25-2014, 12:22 PM
Quoted: 9 Post(s)
buy a set of OEM plugs, gap them correctly, pull apart every electrical connector you can find near the rear of the car, blow the water out of them, use dielectric grease when you reconnect them.
dhirtle is offline
Human Verification
Rough idle on start up 08tkofortwo smart Operation and Maintenance 21 08-07-2014 05:45 AM
Rough idle ronj09 New Members Area 8 08-04-2013 11:51 AM
Rough Idle tpizzuto smart General Discussion 50 07-17-2013 05:47 PM
Rough idle mistyguchie New Members Area 11 01-24-2013 09:15 AM
Rough idle blackbeagle smart Operation and Maintenance 9 04-18-2008 03:05 PM
