Won't go into reverse sometimes - Smart Car Forums
 1Likes
post #1 of 50 (permalink) Old 08-28-2010, 06:14 AM Thread Starter
SmartDinkyinMO's Avatar
It only happens once in a while over past 6 months, when I first start my car, it wont go into reverse, just from park straight into neutral, I have to keep playing with it or shut it off completely and restart it, then finally it will go into reverse. It doesnt happen all the time just every once in a while, can anyone tell me what this might be? I bought my car at carmax in mo. They said to take it to a smart car dealership, but what if it doesnt do "it" when they look at it, like I said it only happens once in a while. Thanks Jen in Mo.. My lil Dinky.
SmartDinkyinMO is offline
post #2 of 50 (permalink) Old 08-28-2010, 06:30 AM
Brabus007's Avatar
Quoted: 84 Post(s)
There ia a firmware update for that problem at your Smart Dealer... Take it in... Are you still under warranty...???
Its a known problem...<:-((
Brabus007 is offline
post #3 of 50 (permalink) Old 08-28-2010, 06:32 AM
Quoted: 84 Post(s)
You didn't say what year it is..........BUT..........it sounds like the clutch issue.
IF it's still under warranty, take it to the dealer for replace/software update...
IF not, still take it in but it will be on YOUR dime
As Brabus007 said...........known issue
chieftmc is offline
post #4 of 50 (permalink) Old 08-28-2010, 06:53 AM
BB Benz's Avatar
Quoted: 226 Post(s)
I would press the issue if you're out of warranty, take it to the level of smart usa, because it is a known issue and needs the software update. Why wouldn't they do it for free? IT IS A DESIGN FLAW.
BB Benz is offline
post #5 of 50 (permalink) Old 08-28-2010, 07:03 AM
Mine started having that problem a few months ago. I did the transmission re-train sequence and it hasn't done it in about 2 months. It had been increasing to 2x/week.
SuperGeek is offline
post #6 of 50 (permalink) Old 08-28-2010, 07:09 AM
BB Benz's Avatar
Quoted: 226 Post(s)
Actually PNRND.
[QUOTE=SmartDinkyinMO;365920]It only happens once in a while over past 6 months, when I first start my car, it wont go into reverse, just from park straight into neutral....
The smart transmission on a day when it is working perfectly: will display an N between park and Reverse and also between Reverse and Drive.
It goes through neutral and displays the N between gear selections in auto mode. I noticed that by chance yesterday as the little Benz took me to lunch yesterday from work, and we were spending some quality time togeher.
BB Benz is offline
post #7 of 50 (permalink) Old 08-28-2010, 06:43 PM
gstreetcomic's Avatar
Quoted: 7 Post(s)
I know i am having that same little issue and it was fixed under the warranty. I am going to nicely pursue the dealership for this one as it is happening again. I am not really that thrilled myself.
And i really like my car too.
gstreetcomic is offline
post #8 of 50 (permalink) Old 08-28-2010, 08:32 PM
SmartDigger's Avatar
Quoted: 176 Post(s)
I had mine done under warranty. It no longer comes home smelling like burnt clutch. Which was considered normal before the new clutch.
SmartDigger is offline
post #9 of 50 (permalink) Old 11-29-2010, 10:00 AM
Quoted: 2 Post(s)
This happened to me last week before we traveled. After a few tries, it engaged and worked.
On our return to the airport, it took some 15 to 20 tries before it engaged.
It has worked fine since. We have 20,500 miles and are 6 months beyond the 2-yr warranty. Have the smart-branded "extended" warranty.
If they claim that the clutch is a wear and tear item and refuse to cover this, I'll be disappointed. Clutches should not wear out after 20,000 miles.
vwW12 is offline
post #10 of 50 (permalink) Old 11-29-2010, 10:49 AM
jayskulls's Avatar
Happened to me as well. It seems to happen mostly when there is even the slightest slope where your front tires are. I noticed it only happened in this one parking spot at work that had a slight dip in the front. I'm going to have them look at it when I bring it in for my 20k checkup.
jayskulls is offline
Human Verification
331
Stuck in N when I try to reverse Egadfly smart Operation and Maintenance 87 11-12-2012 06:24 PM
Not finding Reverse c20500 smart Operation and Maintenance 10 10-08-2009 05:26 AM
when im in reverse (Re: noise) chobocobo smart Operation and Maintenance 9 09-19-2009 06:15 AM
Reverse Limiter W/B Smartie smart Operation and Maintenance 4 03-31-2009 11:35 AM
Problems getting to Reverse Donate2Educate smart General Discussion 1 07-12-2008 10:33 AM
