Easy Head-Light Pod Removal/ Horn Access - Smart Car Forums
 1Likes
  • 1 Post By mvaldes
post #1 of 7 (permalink) Old 11-16-2011, 01:58 PM Thread Starter
BB Benz's Avatar
Quoted: 226 Post(s)
Why not just post the procedure so everyone can see...
Here's HOW TO-
TAKE OUT YOUR HEADLIGHT PODS WITHOUT REMOVING THE FRONT OF YOUR CAR, OR SIDESKIRTS:
You will first follow the excellent photos and description on Evilution and stop before removing the pictured bottom side torx 25 bolt at the Bottom of the fender as shown in the link below.
It is not necessary to remove the side skirts, or the turn signal repeater since the fender will not be coming off the car.
Thank YOU Kane very, very much for the Evilution Link that follows:
I do remove all three screws including the one holding the retaining strap for the flap and the pins on each fender just below the innermost bottom edge of each head lamp. A tack puller is great for these pins.
Once you have worked your way down just prior to removing the fender bolt, the fender is now floppy loose and can be easily bowed out by hand since it is springy and highly flexible, so that a screw driver can be inserted to loosen the third screw beneath the rear of the headlight pod. If you scroll past the lower fender bolt location on the evilution site above, you will see the red circled locations of the pod bolts...
Unscrew, lift out the pods, and unplug. Piece of cake.
YOU now also have access to the wimpy horn. The Wolo Bad boy will mount on the original horn mount and plug right into the OEM connectors. AS always, orientation is important. You don't want your air horn gurgling or drowning. Wolo's are usually stocked by Harbor Freight. Nautilus compact truck horns are similar but have a singular 300 Hz. Deep voice. Perfect for tiny cars!
So, you have now removed the headlight pods, accessed the horn, and NOT had to completely denude the front of your car, NOT get a friend to help, NOT have had access to padding to place your fenders on so they don't get scratched on the pavement, NOT dealt with unplugging fog lights or Brabus air dams OR side skirts, NOT dealt with jacking the car, which means owning a jack so you could remove the wheel to gain access to the horn through the wheel well etc.
I do recommend protecting the fender from the screw driver when removing the bottom rear pod screw, and using a magnetic screw driver so you don't drop that pod screw. They are like marbles. They will always roll to the furtherest most unreachable location UNDER the piano. I always keep one of those handy so I know exactly where the dropped screws will be!
BB Benz is offline
The Following 5 Users Say Thank You to BB Benz For This Useful Post:
JamesWeatherford (02-16-2012), jetfuel (11-16-2011), jwight (11-16-2011), KP4 smart (11-16-2011), redoregon (11-17-2011)
post #2 of 7 (permalink) Old 11-16-2011, 02:32 PM
Quoted: 68 Post(s)
Thanks very much! I think the original horn replacement thread by SMART (remember him?) used this technique since he didn't remove the front panels.
http://www.smartcarofamerica.com/for...t=replace+horn
jwight is offline
post #3 of 7 (permalink) Old 11-16-2011, 03:10 PM
Quoted: 22 Post(s)
But what do you do if you don't have a piano?
(Thank you for the excellent tutorial.)
mvaldes is offline
The Following User Says Thank You to mvaldes For This Useful Post:
BB Benz (11-16-2011)
post #4 of 7 (permalink) Old 11-16-2011, 07:17 PM Thread Starter
BB Benz's Avatar
Quoted: 226 Post(s)
Then use that cop car that always pops out of the tailgate when you speed.
I always find that piano in my back pocket AFTER weighing in at the Dr.'s office.
BB Benz is offline
The Following User Says Thank You to BB Benz For This Useful Post:
mvaldes (11-17-2011)
post #5 of 7 (permalink) Old 11-16-2011, 07:35 PM
ManchVegas's Avatar
Quoted: 23 Post(s)
I had my WOLO Bad Boy installed in front of the radiator. I wanted it more front-and-center.
(this pic taken when I had damaged right front quarter replaced)
ManchVegas is offline
post #6 of 7 (permalink) Old 05-13-2013, 08:42 PM
Red Rocket
smartyone's Avatar
Quoted: 13 Post(s)
I'll chime in.... I have had mine out several times and easily, I have it apart in about 5 minutes. Pulling the side skirts and everything. Don't be deterred, it sounds much harder than it is.
smartyone is offline
post #7 of 7 (permalink) Old 03-09-2016, 09:03 AM
Quoted: 22 Post(s)
I thought I'd resurrect this thread since it's probably about time that other members will also need to replace their upgraded horn. After 8 years of faithful service, my Wolo died and I decided to give BB's approach a try. For me, without an assistant handy, it was easier than taking off the front end and way easier than going through the wheel well. (I've done both.) This approach worked quite well. I did have to take out the T25 bolt at the bottom of the fender to get things "floppy" enough to access the headlight pod screws. But, perhaps since I was just replacing the Wolo, I was able to just push the headlight pod to the side without disconnecting and removing it. It wasn't spacious, but I did have enough room to swap out the horn.
Thanks BB Benz.
chieftmc likes this.
mvaldes is offline
Human Verification
331
Head light adjustment SmartDigger smart Operation and Maintenance 6 10-16-2011 02:54 PM
Help with head light bulbs.... chieftmc smart General Discussion 16 09-13-2011 06:42 PM
Head light cleaning SmartDigger smart Operation and Maintenance 6 08-24-2011 06:35 PM
head light out skychef smart Operation and Maintenance 6 01-06-2011 07:41 AM
need a new head light maxtraxduffy smart Operation and Maintenance 10 04-23-2010 03:07 PM
