Problem! RUNING OUT OF FUEL. - Smart Car Forums
 2Likes
  • 2 Post By BARNEY O
post #1 of 9 (permalink) Old 08-18-2014, 08:12 PM Thread Starter
16.luca's Avatar
Quoted: 20 Post(s)
GT1548
When boost hits about 4psi and on wards it leans out like crazy. I have my SS box cells maxed out at 25.5 where bedded and still not enough fuel to feed my GT1548.
Don't know what to do???
Bigger injectors more fuel pressure???
16.luca is offline
post #2 of 9 (permalink) Old 08-19-2014, 06:32 AM
BB Benz's Avatar
Quoted: 226 Post(s)
I know of at least three running bigger injectors on turbo smarts.
BB Benz is offline
post #3 of 9 (permalink) Old 08-19-2014, 08:26 AM
GONE FOR GOOD...
WhiteNBlack08's Avatar
Quoted: 357 Post(s)
+1. You can't make more power if you can't supply more fuel...
WhiteNBlack08 is offline
post #4 of 9 (permalink) Old 08-19-2014, 10:30 AM
BARNEY O's Avatar
Quoted: 123 Post(s)
Originally Posted by 16.luca View Post
GT1548
Do you have a stand alone (separate) A/F gauge and sensor to monitor exhaust ?? You cannot use the signal from the sensor the piggyback is reading from as its trying to fool the ecu into thinking the engine is lean so that it will add more fuel... The piggyback works just the opposite you think it would... Its all about keeping the factory ecu happy...
jwight and jsenka like this.
BARNEY O is offline
post #5 of 9 (permalink) Old 08-20-2014, 07:59 PM Thread Starter
16.luca's Avatar
Quoted: 20 Post(s)
@Barney
Yes I do have a separate air fuel ratio and boost gauge it's the aem failsafe boost and air fuel gauge in one.
Yeah we noticed that if you add higher numbers to the cells it doesn't richen the mixture it leans the mixture. It's seems like it's backwards the way you have to tune with the SS box.
I got my map sensor voltage perfect
Original map sensor V: 3.72v @ -1hg
SS box map sensor V: 3.73v @ -1Hg
-28Hg cell set to 10.4 and auto filled to -1Hg
Then set the 0Hg and 0.5 psi cells to 18.4. Auto filled from (0.5psi) 18.4 to 16psi and already set that to a cell value of 8.
When the key is off and I also tapped into a 12 V supply after the key is off which happened to be pin 66 or 73 on the ECU top smaller plug. It turns off exactly 1min. That should be perfect my map sensor setting for my area, Scottsdale AZ.
16.luca is offline
post #6 of 9 (permalink) Old 08-20-2014, 08:05 PM Thread Starter
16.luca's Avatar
Quoted: 20 Post(s)
@Barney O
I do have a weird idle where it fluctuates up and down it's so weird!
Any clues as to why and how to cute it??
My vacuum is between -17hg and -19hg
Checked all connections and no vaccine leaks found.
I was rich before and it seem to clog up the O2 sensors because I was getting a vacuum reading of -12hg -11hg but let the engine breathe a little bit giving a few good shots of throttle and it cleared up the O2 sensor's and my vacuum went back to normal again.
My settings for the enrichment setting is set to 7 psi.
With output B to pressure only.
Do you think you can PM me your phone number so we can talk on the phone??
Please??
16.luca is offline
post #7 of 9 (permalink) Old 08-20-2014, 09:11 PM
BARNEY O's Avatar
Quoted: 123 Post(s)
I'm on vacation ... Call Mark @ Split Second and have him walk you thru the steps...
BARNEY O is offline
post #8 of 9 (permalink) Old 08-21-2014, 09:28 AM Thread Starter
16.luca's Avatar
Quoted: 20 Post(s)
@Barney O
I already have, I set up the map sensor as per their tech notes and also mark and Dan helped me out.
Of course you are on vacation I won't be bothering you.
Would your email suffice and I will keep in contact with you after you return. I don't want to ruin your vacation.
16.luca is offline
post #9 of 9 (permalink) Old 08-21-2014, 09:10 PM Thread Starter
16.luca's Avatar
Quoted: 20 Post(s)
@administrator you can close this thread
I've figured out the problem,y upstream O2 sensor was disconnected grrr.
16.luca is offline
Closed Thread
Human Verification
331
Removal of fuel tank and fuel pump dhirtle Technical "stickies" 1 08-31-2015 05:13 PM
Fuel injection questions - Injector cc/min and operating fuel pressure ilomax smart Modifications 37 06-23-2013 11:36 PM
Fuel Indicator problem amitchell smart General Discussion 9 06-25-2009 08:54 PM
Answer to our energy problem? Algae fuel and a Smart(or 2) in every garage deltadart smart General Discussion 24 07-03-2008 04:04 PM
Fuel Gauge problem smarish smart Operation and Maintenance 3 06-20-2008 05:37 AM
