The SMART CAR OF AMERICA community is a social utility that connects you with fellow smart enthusiasts.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact contact us.
..ok..so the problem with the lack of lube develops all of the sudden with a "can't move the shifter or is there a time when the shifter becomes hard to move and that's the first sign of time to lube...know what I mean Vern?
It is the release button on the front of the shifter knob that gets hard to move (depress). The inner end of the release button has a horizontal sliding cam working 90-degrees against a vertical plunger in the shifter shaft. the plunger is only plastic with very little bearing surface to spread the load - sort of like if a valve cam worked directly on the end of a pushrod or valve stem.
Reason: add depress
jetfuel
I don't think it develops over time, it just was NEVER lubed
The button on my shifter started to feel "rough" (that's the best way I can explain it) and was getting a little harder to push. When I opened it up, it was dry as a bone ! Lubed it up and it's "better" than new
Just take off the knob and look at it and feel it. There was no detectable lube on my 'o8 so I used white lithium grease. It's been fine for the the 9000+ miles since. This thread shows you how to do it. It's really very simple: DIY gear shift removal and lube (short video)
Hope that helps
Reason: clarity
