451 feature discoveries - Page 14 - Smart Car Forums
 13Likes
post #131 of 138 (permalink) Old 12-19-2016, 02:14 AM
MegaChar's Avatar
Quoted: 4 Post(s)
Some finds that I found recently.
Somehow My Smart has two not one "neutral " gears for some odd reason "P N R N D +-" is how the transmission is set up. I don't really see a point to two nuteutral gears but mehh. I love my Smart's really weard and cool features.
Smart's are alive??? My friend bought a battery operated amp ment for guitars and desides to turn it on in my car while we are going down the road...Right as its turned on,you hear a pitch noise that gets higher or lower pitch and for a few mins I wonder what it is while my friend freaks out saying "Your car's alive!! Your car's alive wholly Sh**". I'm trying to calm him down with the "My car is kinda weard I know"....
So yea some interesting things
MegaChar is offline
The Following User Says Thank You to MegaChar For This Useful Post:
vadsoom (12-21-2016)
post #132 of 138 (permalink) Old 12-19-2016, 07:49 PM
Quoted: 252 Post(s)
On US models prior to 2011 there were two mechanical levers - you had to pull both to get the tailgate open.
There's two on the '13, but you only need to pull one.
Smog pump doesn't turn on in 41F weather or thereabouts. Thought mine was broken until I started it around noon when the gauge read 74F, and it did start up....
(Sorry if this is mentioned before. I'm too lazy to read through all the posts on this thread!)
Sent from my iPad using Tapatalk
jzchen is offline
post #133 of 138 (permalink) Old 12-19-2016, 08:19 PM
Quoted: 68 Post(s)
Could you post a photo of your gear selector? All NA 451s have the same PRND sequence on the "auto" side. and the "+" "-" setup on the "manual" side.
Originally Posted by jzchen View Post
There's two on the '13, but you only need to pull one. Those are electrical; the 2010s and earlier are mechanical.
(Sorry if this is mentioned before. I'm too lazy to read through all the posts on this thread!) Covered in the owners manual...
jwight is offline
jzchen (12-19-2016)
post #134 of 138 (permalink) Old 12-19-2016, 08:23 PM
Quoted: 252 Post(s)
I may have an incling of what's going on with the shifter. If you are mid positions, moving from one to the next I notice it will note N....
jwight, Neonspinnazz and MegaChar like this.
jzchen is offline
post #135 of 138 (permalink) Old 12-19-2016, 10:03 PM
MegaChar's Avatar
Quoted: 4 Post(s)
Mine does that. The gears letters on the gear box dosn't say another N but when its in between P and R then dashboard indicates the N gear then R then N then D. Ive never really understood why I might have two neutral gears. Maybe the clutch has to engage into N to shift gears? Hmmmmmm.....
Eather way...Just another weard cool thing about my Smart
MegaChar is offline
jzchen (12-20-2016)
post #136 of 138 (permalink) Old 12-20-2016, 07:32 AM
Quoted: 252 Post(s)
Having very little knowledge about manual transmissions/read unable to drive a manual, I thought if you just push the clutch in you were basically in neutral? Same thing here as it is an automated manual. It has to "push the clutch in" and it is basically in neutral?
jzchen is offline
post #137 of 138 (permalink) Old 12-20-2016, 09:59 AM
Quoted: 480 Post(s)
Technically, if the trans is not in a gear, it is in neutral. if the clutch pedal is depressed, or the actuator is energized, it is in an uncoupled state and not really in neutral. I know, just a technical wording thing, unless you are taking a test or something it doesn't matter.
I went round and round on a car the customer said makes noise when he puts it in neutral. Finally figured out he meant pushed in the clutch pedal and the throwout bearing was making noise
jimvw57 is offline
The Following 2 Users Say Thank You to jimvw57 For This Useful Post:
jzchen (12-20-2016), Neonspinnazz (12-20-2016)
post #138 of 138 (permalink) Old 12-20-2016, 11:03 AM
Neonspinnazz's Avatar
Quoted: 143 Post(s)
That would be correct. If the shifter is in-between gears (or the module thinks it is) it'll indicate N...and it will roll freely if you let it (don't ask me how I know).
Now, if the shifter is not in-between gears and it is still indicating N anyway, I'd have that checked!
Neonspinnazz is offline
Human Verification
331
451 miles on my most recent tank! 451 in a 451! unicycle smart General Discussion 1 04-09-2010 08:45 PM
Auto down feature brett2658 smart Modifications 23 07-28-2009 11:37 AM
Please use the search feature... jwight New Members Area 6 05-10-2008 06:22 AM
