Old 05-02-2008, 03:13 PM   #1 (permalink)
MichaelJ's Avatar
Drive: 3 motorcycles & minivan
Air Conditioner Performance
I fired up the A/C today - first hot-ish day to date. The A/C output was pathetic - barely cool (I need to take a temperature measurement).
Comments from others in hot climates? How does it compare to a "standard" A/C? My feeling is that it's going to go to the dealer, but if it's the nature of the beast, I won't bother.
TIA
Michael J.
MichaelJ is offline   Reply With Quote
Old 05-02-2008, 03:18 PM   #2 (permalink)
bradgarbus's Avatar
Drive: 2009 Passion Coupe - FL
TIA
Michael J.
I test drove a passion at the dealer for several miles, about a mile from the dealer we had to turn it off it was so cold.
Did you let it run for a while to see if it improved?
I am getting the black leather, I can imagine that is going to be rough in the summers here in VA... OUCH!
Old 05-02-2008, 03:23 PM   #3 (permalink)
robotbill's Avatar
Drive: 81 Alfa Spyder 04 Exped
Believe it or not it got a bit hot here in Cleveland our A/C worked fine but what also helped was pulling the sun screen overhead in the roof.
robotbill is offline   Reply With Quote
Old 05-02-2008, 03:34 PM   #4 (permalink)
bottlerocket's Avatar
Drive: Blk/Blk Passion, 2005 LR3
pull the sunscreen
use the recirc feature
turn the temp down to at least 68
use at least the third speed
bottlerocket is offline   Reply With Quote
Old 05-02-2008, 05:39 PM   #5 (permalink)
Drive: 2008 Smart ForTwo Passion
I had an issue with another brand vehicle where the A/C wasn't very cold. I read up on it and the general answer was that there was probably not enough refrigerant in the system. I took it into the dealer, they checked and added more and the temp at the vent dropped by more than 10 degrees. I used a portable electronic meat thermometer to check my temps. You might want to check yours (stick the probe into the vent). I would think the temperature readings should be in the 40's with the fan setting on 2 or 3 and the temperature control at the coldest setting.
Old 05-02-2008, 05:45 PM   #6 (permalink)
MichaelJ's Avatar
Thanks for the replies - I was thinking low charge, but wanted a bit more info than just one car.
Output temps should be around 55F for a 134a system. R-12 (RIP) would get a bit cooler.
Old 05-02-2008, 05:48 PM   #7 (permalink)
Smartfor2guy's Avatar
Drive: Smart Passion
Mine will frost your bollocks off!!!!!!!
Old 05-02-2008, 05:56 PM   #8 (permalink)
moderator
Dunerunner's Avatar
Drive: Yellow/Black Passion
MichaelJ
Your output temp will be relative to the return air temp. You should get ~20 deg. of temperature differential across the cooling coil.
Last edited by Dunerunner; 05-02-2008 at 07:42 PM.. Reason: forgot my AC&R training for a second
Old 05-02-2008, 06:05 PM   #9 (permalink)
I tested my other car on days of appx 90 degree temps outside. It's an R134a-based system. An output temp of 55 degrees is unacceptably too warm, even for 134a. I'll test the smart's vent temps when it warms up enough to get a valid reading.
Old 05-02-2008, 06:20 PM   #10 (permalink)
a2jack's Avatar
Drive: 09 Suzuki SX4 . 08 Smart
Our Canadian cousins have had a real battle with their air-cons. Leaking seals, cracked lines etc. Trip after trip back to the dealer, but only short term fixes.
They too, are new to the NA451 and most failures posted so far have been on on the CDI 450. However, the problems may have been caused by the long line runs back to the rear engine, so this may start happening in our cars too.
Many lose the juice over the winter. Search this site for more on our air-cons. A2Jack
Does 'defrost' setting, use air conditioner? mr_Cash Smart Car Operation and Maintenance 15 03-06-2008 05:12 PM
Electronic Performance Mod's? doc540 Smart Car Modifications 6 01-31-2008 07:06 AM
performance ufo Smart Car General Discussion 9 01-01-2008 04:19 PM
Car performance crateampscal Smart Car General Discussion 28 12-14-2007 06:13 PM
Performance Hybrids to Come from Lexus SMART The Car Lounge 0 09-29-2007 01:49 PM
