It's been in the 90's to low 100's here in Southern California the past four days. I've been running the a/c every day but haven't got to the point where I need to turn it down because it's sooo cold so I was starting to think about taking it in for a checkup. However, I read some entries on here about people who turned down the temp all the way and the air became cold quickly and I hadn't done that. As is my normal custom, I set the temp at 70 all the time and figured the a/c would get there as quickly as it could.
Well today on my drive home (98 degree weather) I turned down the a/c temp to 60, no recirculation. The air became ICE cold! And eventually yes, i finally had to turn that sucker down and temp up.
VERY efficient cooling, and from now on if anyone asks I'll also recommend they turn down the temp as well as use recirc and at least the three setting for the fan. Once the car is cool set the temp you want and let the auto temp do its job...
