Anybody else love having the passenger seat belt jam? - Page 3 - Smart Car of America Forums : Smart Car Forum
Old 11-07-2008, 07:51 PM   #21 (permalink)
Owner for 3.8 years
Kermit's Avatar
Originally Posted by Nicholas View Post
OK everyone, here is the "fix" that will NOT damage your seatbelt guide and really doesn't look too bad at all...Go to the hardware store (Home Depot, Lowe's Ace etc.) and find the clear plastic hose section...Purchase approximately four inches (if they will allow that...most sell it by the foot only)... Figure how long a piece needs to be to fit in the vertical slot of the seatbelt guide and cut a piece that long...Slit the piece length wise on one side only (please be careful and don't cut yourself, I was able to use a long pointed scissors)...Now slide this piece of hose in the slot wrapped around one side of the seatbelt guide and the problem is solved!!!
Good job Nick! I was waiting for someone to finally mention that. I would of but decided to shut my mouth in complete fear of someone flame me because it goes against proper seat belt operation that is "clearly stated" in the owners manual.
Old 11-07-2008, 08:07 PM   #22 (permalink)
Been smart for 3.59 years
NCC1701's Avatar
Originally Posted by PeteInLongBeach View Post
Pull the belt all the way out and verify there are no twists and that it's threaded correctly.
I did as you suggest today. There doesn't appear to be any problem in those regards. Thanks.
Old 11-07-2008, 08:11 PM   #23 (permalink)
yellow smart's Avatar
I'm not 100% sure, but I believe that most seat belt problems are covered for the life of the car. Can anyone confirm this?
I seem to remember once back in the day that one of my seat belts would not retract anymore, and Honda replaced the whole thing for me for free.
Yellow-Smart
yellow smart is offline   Reply With Quote
Old 11-07-2008, 08:13 PM   #24 (permalink)
NCC1701 - Definitely contact your dealer if you are having seat belt retractor problems. It's serious and something smartUSA should know about.
Old 11-08-2008, 06:56 AM   #25 (permalink)
Nicholas's Avatar
Can't post pictures, sorry! Heck, I'm not even able to post the Blackstone Laboratories oil sample analysis that I would like to share with those interested. Really though, it is a very simple and cheap fix for the seatbelt guide.
Old 11-08-2008, 02:08 PM   #26 (permalink)
skyzdlimit59's Avatar
I have had the same problem with my passengers. Very irritating!
I appreciate the hose fix idea but I can't picture what you're explaining. Can someone else post a pic, or at least explain again?
Old 11-08-2008, 02:35 PM   #27 (permalink)
Nicholas's Avatar
Look at the seatbelt guide on the top back side of your seat...black plastic guide probably 1/4" thick...there is a horizontal grove where the seatbelt slides thru when pulled out and slides back when retracting back into the seatbelt retainer. In the middle of the guide there is also a vertical slot where the seatbelt can be guided up thru to release it from the guide. This is where you need to slip the plastic hose / tubeing into. Friction holds it in place and blocks the seatbelt from slipping up into the vertical slot and jamming up so it can't roll back into the seatbelt retainer...Hope this helps!
Old 11-09-2008, 01:57 PM   #28 (permalink)
Enormously Nicholas, thanks for the clarification. So all your doing is jamming the opening so the seatbelt can't slide out (and get jammed). Seems like a simple enough fix. I'll try it. Thanks and my husband thanks you too.
Old 11-10-2008, 01:42 PM   #29 (permalink)
Nicholas's Avatar
skyzdlimit59, glad to share the information...I got so fustrated with the seatbelt "jamming" on me, be it either the driver's side or the passenger's side. Whenever I'm driving the wifes' car I have to have either seat all the way back to be comfortable and I really think this position allows the belt to try to come out of the guide somewhat easier. Since preforming this "fix", I've never had the problem again...
Old 11-10-2008, 01:58 PM   #30 (permalink)
Just like this!!
Passenger belt flip stressed member smart Operation and Maintenance 12 10-01-2011 11:05 AM
ISO: passenger seat belt dennisjf1 Archive/obsolete (?) threads 2 05-14-2011 04:20 PM
Passenger Seat Belt Issue kelmac smart Operation and Maintenance 18 05-11-2011 10:18 AM
Seat belt and/or seat belt tensioner replaced vwW12 smart Operation and Maintenance 12 07-28-2010 07:58 PM
passenger seat seat belt gets cought in door upon closing too smart one Modifications and Repairs 4 07-18-2009 02:46 PM
