Automatic Climate control?? - Smart Car of America Forums : Smart Car Forum
Old 02-05-2008, 08:31 AM   #1 (permalink)
I was wondering if the system is a true automatic system. Can you set it on a temperature and auto? Will it not start blowing until that temperature is reached? Just wondering, as I did not actually notice an auto setting? Thanks for your replies..
redsmartpassion08 is offline   Reply With Quote
Old 02-05-2008, 01:19 PM   #2 (permalink)
BandSofC's Avatar
The "auto" part seems to just be the thermostat. The blower speed is manual. Also, the A/C switch must be turned on manually if you need cooling. Haven't needed that yet here!
That's the way it seems to work for me.
BandSofC is offline   Reply With Quote
Old 02-05-2008, 01:40 PM   #3 (permalink)
SmartAzz's Avatar
That sounds perfect for me - exactly how I use systems capable of being fully automatic anyway
Old 02-05-2008, 01:41 PM   #4 (permalink)
smart happens here!
SmartCard's Avatar
Good question, don't know how the fortwo handles this. Presumably the fan stays on whatever speed you have it set for, and most likely the temperature is maintained by mixing heated air in with a/c air, and not by cycling the a/c on and off.
Old 02-05-2008, 02:09 PM   #5 (permalink)
The Super Shoe
mdfortwoguy's Avatar
From what I can tell, it is similar to the system MB used in the 2000 C230s, and used in their Sprinters through 2006. All it controls is temperature.
From my experiences with it in both the C230 and the Sprinter, it works well... you never get a blast of cold air from it because of it being confused or anything.
Old 02-05-2008, 03:36 PM   #6 (permalink)
That is kinda what I thought. I do find it strange though that Smart calls it automatic climate control. There seems to be nothing automatic about it. No problems for me, I just dont think they should call it that, unless that is what it really is. I have met a few that are very fanatical about having auto climate control. I have had it, and it really makes no difference to me. Thanks for the replies.
Old 02-05-2008, 05:10 PM   #7 (permalink)
GHammerly's Avatar
I think the temperature knob is to set the desired temperature, the fan is totally manual.
For example if you set the temperature to 70 in the winter a sevo will open the hot water to the heater core until 70 is reached, than it will gradually close and open the valve to maintain 70.
In the summer set it to 70 and it will cycle the A/C pump on and off to maintain 70.
That's why some people call it automatic.
Old 02-05-2008, 08:00 PM   #8 (permalink)
The Super Shoe
It is automatic. it's just a simpler system with less parts to fail. If all it is doing is fading the temperature, it's keeping air moving and keeping the car from getting stuffy.
Old 02-06-2008, 06:40 AM   #9 (permalink)
Above freezing, foggy windows AC cleared the windows quickly. With the thermostat set at 70 it blew warm air lots of glass to clear worked great.
Old 02-06-2008, 12:51 PM   #10 (permalink)
What does the owners manual say about how the heat/ac operates????
Has anyone read the manual for controls???
JIM VINYARD is offline   Reply With Quote
Cruise control availability JRyan smart Modifications 13 03-02-2008 08:59 PM
Climate Control Quality? ex300SRT8 smart General Discussion 4 02-02-2008 10:03 AM
Automatic stick shift???? bob/cathy smart Operation and Maintenance 5 01-20-2008 12:10 PM
Cruise Control Fredvon4 smart General Discussion 2 10-12-2007 07:51 AM
Does the SMART car have speed control? lhoboy smart General Discussion 17 09-17-2007 09:34 AM
