Here is a list of the fuses missing in the NA OpInsts by number, circuit, amps, and fuse color. The list can be copied out of this posting and pasted into a text document; column-formatted; re-sized; and pasted (glued) on the blank page of the OpInst. Evilution has a very clear color photo of both sides of the fuse block with all the info.
# Circuit Amp Color
22 Low beam light, left 7.5A Brown
23 Low beam light, right 7.5A Brown
24 Brake lamp, rain/light sensor, combination switch left 15A Blue
25 High beam lights, left 7.5A Brown
26 High beam lights, right 7.5A Brown
27 Engine 7.5A Brown
28 Rear window heater (coupe only), engine cooling fan 40A Orange
29 Soft top (cabriolet only) 30A Green
30 Transmission 40A Orange
31 Horn, doors, central locking 20A Yellow
32 - -
33 Ignition 50A Red
34 esp 40A Orange
35 Power steering 30A Green
R1 Mirror heating 5A Lt. brown
R2 - -
R3 Backup fuse (ignition) -
R4 Backup fuse (ignition) -
R5 Backup fuse (batt. +) -
R6 Backup fuse (batt. +) -
R7 Backup fuse (batt. +) -
R8 Backup fuse (batt. +) -
R9 Seat heating 20A Yellow
For Old SGM: The brake light fuse is #24, not #34.
