Cabrio removeable bars creaking? - Smart Car of America Forums : Smart Car Forum
Old 03-18-2009, 10:46 AM   #1 (permalink)
Happy 2012!
Anyone else have the removable bars on the Cabrio top that creak? When the top is in the closed position I can hear it on bumps but its not bad, but when I roll the top back (push the button and let go) its really noisy.
Dealer said lots of complaints but nothing can be done about it, has anyone else experienced this and any resolutions?
Old 03-18-2009, 11:35 AM   #2 (permalink)
jayhead000's Avatar
yeah i hear creaks on right side, but it doesn't get worse with the top back. probably no solution unless you can find some lubricant of some sort.
jayhead000 is offline   Reply With Quote
Old 03-18-2009, 11:58 AM   #3 (permalink)
smart fortimo's Avatar
Removeable bars
I've set up my cabrio bar permanently and I try to stay on the interstate to avoid sloshing.
Oh, THAT bar...
No, I don't have any weird noise when lowering the top or driving.
Old 03-18-2009, 12:35 PM   #4 (permalink)
Smartmadness.com
2micro4u's Avatar
Im at 30,500 miles and have not experience this problem yet with my cabrio.
2micro4u is offline   Reply With Quote
Old 03-18-2009, 04:41 PM   #5 (permalink)
Happy 2012!
Mine is worse on the right side vs the left side.
Old 03-18-2009, 04:43 PM   #6 (permalink)
SunDiego's Avatar
I don't have this noise.. *knocks on wood*
Old 03-18-2009, 05:57 PM   #7 (permalink)
Padawan's Avatar
How cold is it right now where you live? My Boxster used to creak when it was cold out, but a bit of silicone spray on all of the rubber and plastic wear areas solved the problem.
Old 03-18-2009, 06:06 PM   #8 (permalink)
smartHHO's Avatar
While we on Bars, anyone had an issue with the rubber tacky seal wanting to stick to the front of the car where it meets? My passenger side is all whacked and looks like spider web when I take it off. Going to be talking with the mechanic tomorrow about it along with my steering having a grinding noise.
Old 03-19-2009, 06:03 AM   #9 (permalink)
headless's Avatar
Yet again this is a problem we have had in Britain, and solved easily.
Get some silicone grease for rubber lubrication, can be found at all good car accessory shops, and coat all the rubber parts and that stops the rattles and squeeks.
Also put the grease into the running rails and it helps the roof to retract and saves the motor.
Ellis
Old 03-19-2009, 12:50 PM   #10 (permalink)
eqwalker's Avatar
Ellis
Agreed. I found some silicone rubber lubricant in an auto mag. and applied it to the hard rubber that goes around the inside of the door sill on my coupe because there was rubber to rubber squeak everytime I hit a bump. Took care of the problem perfectly. It has even survived several washes and still does not squeak. I will be getting my cabrio this weekend and will know what to do now.
New Pics of our body kit, Rear Valance, Side Skirts, Front Spoiler and Bumper Bars BreathlessPerformance Interior & Exterior Styling 8 01-18-2009 10:36 AM
Bars waldo New Members Area 5 09-03-2008 02:22 PM
Those unreliable gas-tank bars unicycle smart General Discussion 22 07-05-2008 01:43 PM
failure to start- 3 bars smart1 smart Operation and Maintenance 2 03-10-2008 07:53 AM
