car problems...need help - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 10-22-2009, 06:20 AM   #11 (permalink)
Originally Posted by Dunerunner View Post
randy, are the tires stock or have you purchased something else, a different size? Do you think the tire change was recent enough that it could be causing the problem?
I'm trying to figure out why the car just suddenly started doing this.
Good luck with the battery disconnect reset!!
I would think that IF that were the case, it wouldn't happen in just 5th gear !?
I would "reteach" the tranny and see what happens
Old 10-22-2009, 06:22 AM   #12 (permalink)
i bought the tires from the dealer and i dont think its the tires cus it started hapening about 2 months after the tire change .
randygt is offline   Reply With Quote
Old 10-22-2009, 06:26 AM   #13 (permalink)
how do i reteach the trany,take it to the dealer..?
Old 10-31-2009, 06:59 PM   #14 (permalink)
so i tried disconnecting the battery and reconecting it back and tryin it again and it seems to be doing the same thing you start to drive once you get into top speed for some time after 4th it dosent want to change gears or shift its like your locked into that gear untill you come to a stop put in netural and turn off the car and turn it back on ,,soon as the 3 bars on the dash starts flashing thats it your stuck at that gear the trany wont shift or do nutin..seems like there,s a problem with the tranny not knowing what gear its in so it shuts down ...anyone have this problem..
Old 10-31-2009, 07:17 PM   #15 (permalink)
Gilbert's's Avatar
motor shifter problem see your dealer...
Old 10-31-2009, 11:14 PM   #16 (permalink)
Before you go to the more complex diagnosis process, check your battery voltage - if you've got a 450 and have a few years into the car, there's a possibility that low voltage is confusing the computer, especially if you've got lights or other things on, or an alternator starting to go bad. Voltage should be at least 11.5 (preferably higher) with engine and lights off first thing in the morning, or 13+ volts while running. Low voltage will affect computer signaling, headlights, even shifting - remember, that's an electric motor that drives the shift process. It was evident when my 451 had the smaller, 42Ah battery - after 8 months, shifting was slower, and the lights dimmed between gears.
Old 11-01-2009, 12:12 AM   #17 (permalink)
Mad about smarts and Cats
BB Benz's Avatar
sounds like a question for evilution.co.uk
I suspect Kane will know!
BB Benz is online now   Reply With Quote
Old 11-01-2009, 01:30 AM   #18 (permalink)
Drive: Pulse
Sounds to me like The Three Bars of Death (TM)
Rather than going on about it here, I direct you to our friend Dr. K. Harrison
Old 11-01-2009, 10:34 AM   #19 (permalink)
i have lots of battery power so that cant be the problem but ill check it ayways ....and for the web site i checked it and it gives you alot of options to go through to find out the problem ..acording to the diagnosstic scanner that i have that i pluged in and it came up speed sensor but i put a new one in and still the code comes up the same thing ...and the abs light blinks on and off once in a while and the triangle stays on ,on the dash...????something is wierd here...and the three bars show up flashing..
Old 11-03-2009, 11:08 AM   #20 (permalink)
i can drive the car up to 60 km i believe 4th then anything beond that then the 3 bars show up
Problems so far.. Garcia smart General Discussion 37 07-04-2009 07:07 PM
A/c Problems satchelretired New Members Area 1 03-19-2009 10:36 AM
Battery problems? txlonghorn Texas Chapter 2 02-15-2009 02:14 PM
Power ( acc ) Problems xakkaxxx smart Operation and Maintenance 11 11-15-2008 09:30 AM
Key Problems SeaDoc smart Operation and Maintenance 5 06-16-2008 03:38 PM
