Originally Posted by jrfuisz
There are several different problems here that people are confusing -
1. The recall for the cars that get stuck in Park. From what I've found on the forum, there was a problem with certain cars on the line. They know the VIN numbers of the potential cars effected. There is a bulletin out on this. That problem was resolved at the factory and they tried to catch any cars coming in to fix the issue before the cars were delivered.
2. There is the normal tranny problem where occasionally the shift lever comes out of sync. That is where you get the 3 bars and re-teach the computer where the lever is. That is an easy fix - at page 132 of the manual. The only problem is the manual is wrong - you need to run the lever through the gears after waiting the 30 seconds. I'm guessing everyone is going to have to do this at some point as part wear - not a big deal at all.
3. It looks like there are engine light ECU issues, but I suspect that there will be a software update at some point to correct those issues.
4. My tranny ECU fried which means electrical short of some sort. I haven't found any other issues with the tranny ECU. I've found a few bad transmissions which were replaced. BUt nothing where the ECU fried.
MY $0.02 -
Problem 1 is unfortunate, but it is has been resolved and not it is just an issue of working out the problem with the cars that made it out to customers before the problem was known. 2 and 3 are teething issues. All new products have them to some extent.
My problem is a combination of getting parts (to be expected on some level) and the cause of the problem. I have no reason to believe that Penske will not get the parts. The question is can they find and find what fried the ECU. That is why I lemon lawed the car. If one ECU fries, just replacing it only buys me time until it fries itself again. Unless it was on on board short, there is a problem somewhere else in the system.
We understand your problem may be with the ECU. And I merely posted a heads up on the shifter fix as Smarty was stuck with her car out in a parking lot.
But since you brought it up, where did you find that Smart had issued a recall notice on the shifter? I have not seen recall notice ONE from any of the problems we have encountered in the field. Do you have some new info?
PM me as I don't wish to further dilute this thread. Thanks. A2Jack.
