Car wouldn't start... and then did - Smart Car of America Forums : Smart Car Forum
Old 04-18-2009, 09:56 PM   #1 (permalink)
unicycle's Avatar
I have turned off the car many times when coasting to a red light. On rare occasions the car won't start again right away until I put the car back in D (rather than N, which normally works fine). A handful of times I've had to take the key out and then start the car up from there.
But a couple nights ago, the car seemed unstartable. I tried my tricks, jiggled the gear shift, and so on. The lights in the cabin came on, but the engine didn't make a sound. It seemed like the starter might have died (I've been warned). I phoned the wife and told her I might need to call smart roadside.
Five minutes after I'd given up on my attempts, I tried one more time. Vrooooom. And since that time, the car's been fine. Any ideas on what why the car wouldn't start... and then did?
Old 04-18-2009, 10:07 PM   #2 (permalink)
Red Roller Skate
fpage77's Avatar
That's convient when you have one of those tanks behind you honking their horn like crazy telling you to move. I'd watch out they might run over you in that little car. I would have smart look at it.
Old 04-18-2009, 11:20 PM   #3 (permalink)
Not to be a smartass (pardon the pun), but I'd start with the fact that you're doing something you're not supposed to be doing. Turning it off when coasting to a red light? Starting it while in N? What, in God's name, for? To eke out an extra half-mile to the gallon while putting undue stress on your starter, electrical system, and car in general, not to mention putting yourself in danger? :::shaking head:::
Old 04-18-2009, 11:36 PM   #4 (permalink)
Drive: Pulse
Don't the injectors shut off while coasting?
Old 04-19-2009, 12:21 AM   #5 (permalink)
curtis's Avatar
what he said...
Old 04-19-2009, 01:43 AM   #6 (permalink)
Dave777's Avatar
Yes, they do, which is why I think it odd to shut it off while coasting. I can understand shutting it down at a light, after stopping, if one knows the light will be red for a good bit. I do that too.
Old 04-19-2009, 08:49 AM   #7 (permalink)
jefferios's Avatar
While I don't care for the practice your doing, it seems harmful in the long run. My only suggestion is to have Smart look at it.
Old 04-19-2009, 11:10 AM   #8 (permalink)
I agree that undue stress is the most likely cause. Consider testing the whole starting system, including battery. It takes a LOT of energy to start an engine, even a 3 cylinder. Starting systems are designed with MTBF calculated for 2, 4, maybe 10 starts a day, not at each stoplight. In a "normal car" you'll get 5-8 years on the starter @ 3-4 starts per day. The battery will last 4-5 years if it's allowed to charge for 30 minutes after it's used to crank up. Yes, it can take 30 minutes to trickle charge from a 5-second start cycle. Why? The alternator's not designed to recharge 10-20 times a day every day, while maintaining spark and other demands.
This is why I believe that shutting off the engine does more harm than good (in addition to the heat cycle... water pump doesn't operate, temp spikes in one area, drops in another). It's all adding age to the car's components about 3-4 times normal rate. I'd expect some things to start failing after a year or two, yes.
Old 04-19-2009, 11:56 AM   #9 (permalink)
headless's Avatar
Well, just when you thought you'd heard everything!!!!!
Why would you shut everything off coming up to a red light?
What is the idea behind this practice?
Car won't start in D, has to be in park or neutral, so not sure you know what you are on about!
Old 04-19-2009, 12:12 PM   #10 (permalink)
JOIN SCOA.YOU'LL BE GLAD
..that's one of the issues...the OP said he had to put in back in D for star..
jetfuel
Car will not start - again! 8X5X5ft smart Operation and Maintenance 2 02-24-2009 11:12 AM
Won't Start - HELP! graphix1998 Interior & Exterior 2 07-25-2008 02:59 AM
Won't start... Nicholas smart Operation and Maintenance 7 05-12-2008 03:28 PM
My car won't start! esrazor smart Operation and Maintenance 3 05-01-2008 07:03 PM
jump start??? maxtraxduffy smart Operation and Maintenance 19 01-27-2008 10:26 AM
