Originally Posted by jediknight36
Thank you so much. Im going to take a look when I shop this weekend. If they dont have it, I can use the item number and have them look it up in the other store's inventory. It looks great. Thanks for the post, and the comment.
I bought it. It's easy to find, in the auto section.
It's actually kind of clunky. It's basically three hollow rods that secure an incredibly cheap fishnet thingie, and has two large plastic end pieces. When it's opened, it really doesn't provide enough stability to hold grocery bags still. But I do like the fact that you can "close" it and push it forward, allowing you to still put stuff in front of it.
Basically, for $12.97, you get something worth $12.97.
For the first few days I was just using a large clear square plastic box, and it worked fine for containing the groceries. I might just go back to that.
Now, while in Wally World, I did buy some $9 floormats, a set of four... look for the cheapies, where one of the two larger ones has a horizontal rubbery section. I cut the upper right corner off the rubbery one to account for the brake and gas pedals, and left the flap on the upper left to cover the footrest area. Seems to work okay, although I might have to tack it down...
