Charging system - Smart Car Forums
 1Likes
  • 1 Post By jimvw57
post #1 of 9 (permalink) Old 04-07-2017, 05:45 AM Thread Starter
pevil's Avatar
Charging system
Hello fellow Smarties,
I'm after some ideas to a problem I have with the charging system on my ForTwo 2008, if indeed it is a problem. Car does a lot of short runs, the other day it wouldn't start, low battery, had to call breakdown as I was away from home, we got it running with a booster and the guy tested the charge, at idle it was showing 14.5volt but when the revs were increased it dropped to 12.7volt, turn on the lights and it was back up to 14.5volt?
I've since changed the battery but it's still the same, I've had the alternator checked and they said that was fine, I know the charging is handled by the ECU so is this normal, or is it a trip to the dealer for a diagnostic and a bank loan!
Thanks in advance.
pevil is offline
post #2 of 9 (permalink) Old 04-07-2017, 07:15 AM
Quoted: 68 Post(s)
How old is the battery and have you had it load tested?
jwight is offline
post #3 of 9 (permalink) Old 04-07-2017, 08:05 AM Thread Starter
pevil's Avatar
I've changed the battery and it's doing the same thing as it was with the old one, thanks.
pevil is offline
post #4 of 9 (permalink) Old 04-07-2017, 11:42 AM
Rustedwrench's Avatar
Quoted: 209 Post(s)
If the alternator will charge at a minimum of 13.5 volts or more at idle with all the electrical accessories on it is good. If the voltage goes down when the engine speed is raised make sure the alternator belt is not glazed or slipping. Maximum charging voltage at higher engine speed is 14.5 volts. The electrical load is monitored by the engine control module but how much control it has over the charging voltage is unclear.
Rustedwrench is offline
The Following User Says Thank You to Rustedwrench For This Useful Post:
pevil (04-09-2017)
post #5 of 9 (permalink) Old 04-08-2017, 09:30 AM
Quoted: 606 Post(s)
Belt slipping?? I have had them slip and not make noise..
jimvw57 is offline
pevil (04-09-2017)
post #6 of 9 (permalink) Old 04-09-2017, 01:49 AM Thread Starter
pevil's Avatar
Thanks guys I'll have a look at the belt and maybe change it, anyone done this, is it much of a job?
pevil is offline
post #7 of 9 (permalink) Old 04-09-2017, 05:28 AM
Niteshooter's Avatar
Quoted: 42 Post(s)
Also check the belt tensioner, I just replaced my alternator and discovered the tensioner was seized.
Niteshooter is offline
post #8 of 9 (permalink) Old 04-09-2017, 05:40 AM
Quoted: 606 Post(s)
I had a tough time getting the tensioner back in place after removing the belt. the new belt was a bit less stretched out I guess. I ended up grinding down an allen wrench to fit between the tensioner and the frame so I could compress the tensioner enough to put the belt in place. I was working from underneath after taking of the splash guard. Once I made up the tool, it was a piece of cake.
Niteshooter likes this.
jimvw57 is offline
post #9 of 9 (permalink) Old 05-19-2017, 11:23 AM
Woody14619's Avatar
Quoted: 75 Post(s)
Another option, as you noted it had lots of short trips, which could cause this:
Try getting a plug-in solar panel to trickle charge the car while it's idle. I have a 2008 ICE that has a similar life (lots of short trips during the week, longer trips on weekends). You'll have to wire in a direct (fused) line to plug into, as the default socket is switched with the ignition. I have a direct line in the glove box, with a cover for when it's not needed. But usually it's got the solar panel plugged in 24/7.
Woody14619 is offline
Human Verification
Charging Theocat0 smart fortwo Electric Drive 8 02-01-2016 05:41 PM
Charging system issue (alternator/battery) thadose Original (450) smart fortwo 2 11-06-2015 05:47 PM
Bosch and Evatran partner to bring EV wireless charging system to the US BigWarpGuy Tech & Gadgets 0 06-19-2013 05:11 AM
need help with ac charging Allanb smart Operation and Maintenance 23 06-17-2010 08:16 PM
World’s first billing system for electric vehicle charging posts BigWarpGuy Tech & Gadgets 5 05-15-2009 03:38 PM
