Check Engine light: Code U0002 - Smart Car of America Forums : Smart Car Forum
Old 07-18-2008, 07:48 PM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
getsmartusa's Avatar
Has anyone had this problem. It occurred a day after picking up my smart. Car drives fine. Have to wait till next Tuesday for service appointment (seems to me there ought to be some priority for a day old new car...oh well)
Cleared the code, but it set again the next day.
- David -
getsmartusa is offline   Reply With Quote
Old 07-19-2008, 03:41 AM   #2 (permalink)
Admin/Mod.
evilution.co.uk
- David -
According to the link: Evilution - Smart Car Encyclopaedia
Network Generic Trouble Codes
U0001 High Speed CAN Communication Bus
U0002 High Speed CAN Communication Bus (+) Open
Now, you could call your dealer and share... Just a suggestion.
Old 07-19-2008, 07:03 AM   #3 (permalink)
how do you clear and check the code numbers, I just got the same with 4900 miles.
Scott
Scott is offline   Reply With Quote
Old 07-19-2008, 10:37 AM   #4 (permalink)
I have an obd II diagnostic code reader. Bought it at Autozone for my other car. They run any where from about $69 to many dollars depending on the capabilities. There is a connector under the dash (above about where you right ankle would be when your foot is on the gas pedal). It has a little door on it which opens from the top.
BTW, some auto stores will loan out the scan tools for use.
-David -
Old 07-19-2008, 12:07 PM   #5 (permalink)
thanks for the info, at that price I might jsut buy one for myself, thanks again for the info and the location of the plug.
4900 miles and still like the car, called about getting an orphaned today.
scott
Old 07-19-2008, 12:40 PM   #6 (permalink)
-David -
Good job, Dave. I always advice pple to get their own code reader. It's portable, self-powered and cheap these days.
Old 07-19-2008, 06:16 PM   #7 (permalink)
If your budget allows, the ScanGauge II costs $159 or less and will read codes and monitor your systems while driving... fuel consumption, water temperature, a bunch of things.
ScanGaugeII - Trip Computers + Digital Gauges + Scan Tool
Save 10 bucks and get it from Amazon or Thinkgeek.com, or order direct from the maker and get the latest update.
Old 07-30-2008, 06:56 PM   #8 (permalink)
Totally got that code. I drove through a lake (not really but my first REEEELLLL bad storm) It cleard itself however im still worried. did the dealer tell you anything? only got 300 miles on mine.
Thnx
NikyTwotones is offline   Reply With Quote
Old 01-15-2009, 10:52 PM   #9 (permalink)
iceaxe's Avatar
check engine light code U0002
most comunication problems are caused by low reference voltage. (weak battery) If your vehicle has the comfort package P51, take your smartie to your nearest dealer for a quick relay update.
iceaxe is offline   Reply With Quote
The Following User Says Thank You to iceaxe For This Useful Post:
smarty54321 (12-06-2011)
Old 03-13-2009, 07:45 PM   #10 (permalink)
I've had my Smart since Christmas Eve. I've got 6100 miles on it already and got the U0002 error code tonight on my way home from work. :-/
So I assume that-- since this is a low voltage issue-- that it's safe to drive the car until maintenance can be performed? I live 80 miles from the nearest Smart dealership, so I typically wait until Saturdays to get my Smart routine maintenance done (I've already been in once for a bad seat belt sensor). If I wait until next Saturday (March 21st) will my car be damaged any further?
Also, I had a small 8" neon plugged into the cigarette lighter (for floorboard lighting) that had a lose wire (it finally came loose this evening). Would this be the potential source of the problem? Or is this something else? I've removed the neon, just in case.
TIA for your advice and comments.
Jason Huebel
Orange, TX
jhuebel is offline   Reply With Quote
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f4/check-engine-light-code-u0002-11397/
- 2008 smart fortwo code U0002 - OBD-Codes.com This thread Refback 11-12-2008 01:59 PM
- 2008 smart fortwo code U0002 - OBD-Codes.com This thread Refback 10-20-2008 12:09 PM
- 2008 smart fortwo code U0002 - OBD-Codes.com This thread Refback 07-21-2008 03:19 AM
Check Engine Light dcrooks smart Operation and Maintenance 218 12-13-2011 02:53 PM
First Tap Tap Noise Then Check Light On smartysmitten New Members Area 7 05-24-2008 09:22 PM
Engine light Phxbird57 Arizona Chapter 9 04-20-2008 12:57 PM
Check Engine Light and CPU Reset Gene_SD smart Operation and Maintenance 1 04-18-2008 07:33 PM
Check Engine Light, 400-500 miles thefitness smart General Discussion 4 03-23-2008 09:33 PM
