Check Engine light: Code U0002 - Page 2 - Smart Car of America Forums : Smart Car Forum
Trailer
Old 03-14-2009, 08:05 AM   #11 (permalink)
unicycle's Avatar
Originally Posted by iceaxe View Post
most comunication problems are caused by low reference voltage. (weak battery) If your vehicle has the comfort package P51, take your smartie to your nearest dealer for a quick relay update.
I'm not sure about the 09s, but I think that they had some battery problems, too. My 08 had some electrical issues, and while that code never came up, I did end up having the battery swapped out. Since then, I've had no problems.
unicycle is online now   Reply With Quote
Old 03-14-2009, 08:27 AM   #12 (permalink)
smartHHO's Avatar
I just bought a OBD II usb connector for laptop and from a guy in Hong Kong for 30 bucks. Seems to be working fine in my Vista, and works great with some software I downloaded that tracks MPG, all the sensors in real time, 1/4 mile speed and everything else. Really nice stuff. Going to test it out later and log my car on when to shift and what not for optimum MPG.
Old 03-14-2009, 08:27 AM   #13 (permalink)
a2jack's Avatar
Originally Posted by getsmartusa View Post
I have an obd II diagnostic code reader. Bought it at Autozone for my other car. They run any where from about $69 to many dollars depending on the capabilities. There is a connector under the dash (above about where you right ankle would be when your foot is on the gas pedal). It has a little door on it which opens from the top.
BTW, some auto stores will loan out the scan tools for use.
-David -
David, What brand and model diag reader did you get?? Were you able to clear the code with this device?
I understand the "Scangage" brand unit will not clear codes which is why I never bought one. A2Jack.
Old 03-14-2009, 08:49 AM   #14 (permalink)
Gilbert's's Avatar
Can you post pic's
Old 03-14-2009, 10:18 AM   #15 (permalink)
I've used the Scangauge to clear codes but my understanding is that there are some it's not "allowed" to clear such - for example, whatever code happens when you get the airbag/seatbelt warning light.
Old 07-11-2009, 09:29 PM   #16 (permalink)
U0002
I had the same error code. Purchased Actron Auto Scanner Plus CP9180 at AutoZone $179. needed to use up my reward points. Cleared it and has not come back on. I do run a 200W inverter in the sig lighter to charge my cell phones on my 78 mile comute to work. Gettin 44MPG 2009 passion with 600+ miles.
graverl is offline   Reply With Quote
Old 07-11-2009, 09:51 PM   #17 (permalink)
eskargo's Avatar
just to confirm mvaldes post. scangauge can NOT clear the airbag warning light.
personal experience: passenger seat was removed without disconnecting the battery. and when the seat was put back, the airbag came on. lucky for me, this happened the same week as my 2.0 upgrade appt. so the dealer took care of it during that visit.
eskargo is offline   Reply With Quote
Old 07-12-2009, 06:16 AM   #18 (permalink)
Scangauge will clear ENGINE fault codes. but not ABS, SRS or other codes. Just clearing the code will not keep it from re-appearing if the original problem is not fixed.
Old 03-03-2010, 09:17 AM   #19 (permalink)
i had this code pop up on my scangauge the other day i was jamming out at night and it was cold so the battery was really working hard to keep up with the demand
i believe this is a low battery warning of some sort
rexxxlo is offline   Reply With Quote
Old 11-02-2010, 02:18 PM   #20 (permalink)
I have seen this issue occur on multiple smarts when starting the vehicle with a power inverter plugged in and in the on position. Once the code is cleared and I start the vehicle before plugging in the inverter everything is ok. I think it is a combination of the draw from the starter and any other accessories (inverters,cell phone chargers, radar detectors etc) that causes the voltage drop that triggers the code. I am willing to bet a few of the previous posters were starting the car with something plugged into the acc port.
momogogi is offline   Reply With Quote
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f4/check-engine-light-code-u0002-11397/
- 2008 smart fortwo code U0002 - OBD-Codes.com This thread Refback 11-12-2008 01:59 PM
- 2008 smart fortwo code U0002 - OBD-Codes.com This thread Refback 10-20-2008 12:09 PM
- 2008 smart fortwo code U0002 - OBD-Codes.com This thread Refback 07-21-2008 03:19 AM
Check Engine Light dcrooks smart Operation and Maintenance 218 12-13-2011 02:53 PM
First Tap Tap Noise Then Check Light On smartysmitten New Members Area 7 05-24-2008 09:22 PM
Engine light Phxbird57 Arizona Chapter 9 04-20-2008 12:57 PM
Check Engine Light and CPU Reset Gene_SD smart Operation and Maintenance 1 04-18-2008 07:33 PM
Check Engine Light, 400-500 miles thefitness smart General Discussion 4 03-23-2008 09:33 PM
