Clutch questions - Smart Car of America Forums : Smart Car Forum
Old 04-22-2012, 05:57 PM   #1 (permalink)
Clutch questions
1) I have not read about any clutch replacements on the forum. Has anybody had to have a new clutch? How long did the original last?
2) Since smarts have a dry clutch, does the clutch wear when you are not moving, your foot is on the break, and the selector is in "D"?
charles_good is offline   Reply With Quote
Old 04-22-2012, 06:24 PM   #2 (permalink)
129K+ miles of smiles
WhiteNBlack08's Avatar
There was a rash of clutch changes on 08's & early 09's. That was until smart figured out a software update to fix the issue. The clutch should last as long in a smart as any other vehicle. Personally, I. Just passed 102K on my smart and I'm still running the original clutch, and never had the software update.
See this thread for an example: How I got my clutch replaced - for those having problems
Old 04-22-2012, 06:45 PM   #3 (permalink)
GeekGirl's Avatar
Mine was replaced at 20k miles. At 54k all is well
GeekGirl is offline   Reply With Quote
Old 04-22-2012, 06:59 PM   #4 (permalink)
Orange Crate turbo coupe
BARNEY O's Avatar
The clutch should always be totally disengaged when your foot is pressing firm on the brake pedal... Some people will tend to ease off the brake pedal just enough at a stoplight or similar to where the clutch will start to engage or drag... The clutch is slipping at this point...
Best to keep good pressure on brake pedal until your ready to go or anticipating to go to get the brake hold feature to release.. Great for hills but not worth a crap on level ground....
Old 04-23-2012, 07:31 AM   #5 (permalink)
a2jack's Avatar
CG. "Since smarts have a dry clutch, does the clutch wear when you are not moving, your foot is on the break, and the selector is in "D"?
The Clutch does not wear, as it is held disengaged by the throwout bearing running against the pressure plate spring race. However both the Bearing and the Plate springs and Race are being worn.
One click of the E-Brake handle disengages everything and is recommended for long holds at stop lights. A2Jack
Old 04-23-2012, 07:37 AM   #6 (permalink)
"If" the clutch is fully disengaged there is no wear on anything except the throw out bearing. "If" the clutch is partially engaged there will be wear on the clutch disk, pressure plate and flywheel.
SLIVERS is offline   Reply With Quote
Old 04-23-2012, 02:08 PM   #7 (permalink)
when it starts to slip.....there is no set mileage for replacing a clutch like your engine oil..how long your clutch will last depends on how you drive and how well the clutch is made.....if you do need to replace the clutch you need to make sure the flywheel gets resurfaced or replaced as well....a warped flywheel will ruin a new clutch in short order!!!!
AnthonyKeene is offline   Reply With Quote
Old 04-23-2012, 02:55 PM   #8 (permalink)
I have an 09 Pure and mine was replaced by the dealer at 48000 miles and cost in the neighborhood of $1400.00 It started to shift hard, as if your foot slipped off a clutch pedal, but it did not slip. The pressure plate and throw out bearing were also replaced in that price.
noodle9 is offline   Reply With Quote
Old 04-23-2012, 03:39 PM   #9 (permalink)
how tough is it to DIY?
kennyrayandersen is offline   Reply With Quote
Old 04-23-2012, 03:56 PM   #10 (permalink)
No tougher than any FWD vehicle. After all, the setup is basically the same. MB says you need to "teach in" the drag point, but I call BS on that one. Reset it to where it was new(if you haven't made an adjustment like I did), and it should be good to go. If it doesn't feel quite right, 3 bolts, and you can make small adjustments.
The Following 2 Users Say Thank You to WhiteNBlack08 For This Useful Post:
a2jack (04-24-2012), kennyrayandersen (04-23-2012)
Clutch actuator edmasfu Archive/obsolete (?) threads 27 07-20-2012 06:47 AM
Clutch chatter? elmosisu smart Operation and Maintenance 12 01-05-2012 02:21 PM
Clutch Poll GeekGirl smart Operation and Maintenance 250 08-09-2010 10:24 AM
A/C Clutch jsenka smart Operation and Maintenance 8 04-24-2010 04:01 AM
Clutch? dingos smart Operation and Maintenance 42 09-27-2009 10:51 AM
